电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 04作业本
共24条 3/3 ‹ 1 2 3 跳转至页
2014-12-25 21:30:29     打赏
21楼
#include "stm32f10x.h"
#include "stm32_eval.h"
#include <stdio.h>
volatile int flag;
                                                      //板子已将PC12脚接到18B20
#define Set_B20()    GPIO_SetBits(GPIOC, GPIO_Pin_12)    //关上PC12
#define Reset_B20()  GPIO_ResetBits(GPIOC, GPIO_Pin_12)   //打开PC12
#define Read_B20()   GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12)   //读PC12
unsigned char Error_Flag=0;
unsigned char zf=0;
/*延时函数 微秒*/
void delay_us(u32 n)
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
/*延时函数 毫秒*/
void  delay_ms(u32 n)
   while(n--)
    delay_us(1000);
void SysTick_Configuration(void)
    /*==========此次作业的部分===========*/
  if (SysTick_Config(48000))                //SysTick配置。48000/48ms=1ms
    while (1);
  NVIC_SetPriority(SysTick_IRQn, 0x0);                       //SysTick中断优先级
GPIO_InitTypeDef   GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
void RCC_Configuration(void)
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_6);     //  PLLMul_X就是X的倍数,即8*6=48HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
//  SystemInit();
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_ResetBits(GPIOD,GPIO_Pin_2);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
    GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void USART_int(long BaudRate)
      RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* PA10 USART1_Rx  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        USART_InitStructure.USART_BaudRate = BaudRate;//??????
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
        USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
        USART_InitStructure.USART_Parity = USART_Parity_No;//????
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
        USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
        USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
        USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
        USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
        USART_ClockInit(USART1, &USART_ClockInitStructure);
        USART_Init(USART1, &USART_InitStructure);
        USART_Cmd(USART1, ENABLE);
        USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void delay_18b20(u32 nus)  //18B20时序要求严格精确,为18B20写的延时函数
    u16 i;                               //这个函数写的貌似是1us
    while(nus--)             //nus每减一次,i减12次
        for(i=12;i>0;i--);
void Init18B20(void)
   u8 aa=0;
   u8 count =0;
     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);  //打开PC时钟
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;         //选中管脚12
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;   //开漏输出
   Set_B20() ;         //拉高
   delay_18b20(1);
     //一、复位:至少480us的低电平信号,当18b20接收到此信号后会回发芯片一个存在脉冲
   Reset_B20();        //拉低
   delay_18b20(480);
     //二、存在脉冲:将数据单总线拉高,接收存在脉冲,通信双方达成基本协议,双方开始数据通信
   Set_B20();     //拉高
   delay_18b20(480);
    count=0;
    aa=Read_B20();   //aa为读得的温度、
/*=====我觉得下面这几句用来统计18B20出现错误的次数,次数到99次的时候报错======*/
    while(!aa && count<100)   //如果温度值和count数都大于100时
    aa=Read_B20();           //再次读温度值
      count++;                 //发生错误了,数值+1
   if(count>=99)             //如果发生错误的次数大于99次,那么报错,标志位为1
        Error_Flag=1;
     else
          Error_Flag=0;          //报错次数未达到99次,正常工作
                             //读一个字节
unsigned char Read18B20(void)//读18b20里的数据,由于是单数据总线,需要一位一位地读
unsigned char i=0;
unsigned char date=0;
u8 tempp;
   for(i=8;i>0;i--)//循环8次
   Reset_B20();   //拉低读数
   date>>=1;      //右移一位
   delay_18b20(1);
   Set_B20();      //拉高
   delay_18b20(1);
   tempp=Read_B20();  // tempp为读得的温度
   if(tempp)
        date|=0x80;
        delay_18b20(60);
    return(date);
void Write18B20(unsigned char date)   //写一个字节
    unsigned char i=0;
    for (i=8; i>0; i--)
        Reset_B20();
        delay_18b20(1);
        if(date & 0x01)
            Set_B20();
        else
        {   Reset_B20();}
        delay_18b20(60);
        date>>=1;
        Set_B20();
        delay_18b20(1);
    delay_18b20(15);
 float Read_T()//
    unsigned char TUp,TDown;
    unsigned char fTemp;
    u8 TT=0;
    float Temp = 0;
    Init18B20();
    Write18B20(0xcc);    // 跳过读取序列号
    Write18B20(0x44);   //
    Init18B20();
    Write18B20(0xbe);   //
    TDown = Read18B20();    //低8位
    TUp = Read18B20();      //高8位
    if(TUp>0x7f)
        TDown=~TDown;
        TUp=~TUp+1;
        TUp/=8;
        zf=1;
    else
    zf=0;
    fTemp=TDown&0x0f;
    TUp<<=4;
    TDown>>=4;
    TT=TUp|TDown;
    Temp=TT+(float)fTemp/16;
    return(Temp);
int main(void)
    int i;
    unsigned char ID1[8];     //定义一个用于18b20id读取和存放的数组
  RCC_Configuration();
  USART_int(115200);
    SysTick_Configuration();
  Init18B20 ();        //初始化DS18B20
    Write18B20(0x33);     //写入“读取序列号”命令
  delay_18b20 (15);
      for(i=0;i<8;i++)
        ID1[i]=Read18B20();   //读取18b20发回的64位地址
    printf(" config done...\r\n");
    delay_ms(1000);
    while(1)
        if(flag == 300){         //300us读一次id
              printf("The id is:");
                for(i=0;i<8;i++)
                printf("%u",ID1[i]);
                    if(i==7){printf("\r\n");    }
        if(flag == 500){         //500us读一次温度
            printf("The Temperature is:%f\r\n",Read_T());
#ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  while (1)
#endif
#ifdef __GNUC__
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  while (1)
#endif
2014-12-25 21:31:45     打赏
22楼
2014-12-25 21:32:25     打赏
23楼
#include
#include
#include "spi_flash.h"
#define VREF 3.3
#define TxBufferSize1   (countof(TxBuffer1) - 1)
#define RxBufferSize1   (countof(TxBuffer1) - 1)
#define countof(a)      (sizeof(a) / sizeof(*(a)))
#define  BufferSize (countof(Tx_Buffer)-1)
typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus;
#define  FLASH_WriteAddress     0x00000
#define  FLASH_ReadAddress      FLASH_WriteAddress
#define  FLASH_SectorToErase    FLASH_WriteAddress
#define  sFLASH_ID              0xEF3015     //W25X16
//#define  sFLASH_ID              0xEF4015   //W25Q16
#define buff_size  16;
char rx_buff_count=0;
uint8_t Tx_Buffer[4096] ;  //发送缓冲
uint8_t Rx_Buffer[BufferSize];  //接受缓冲
__IO uint32_t DeviceID = 0;  //装置ID
__IO uint32_t FlashID = 0; //闪存ID
__IO TestStatus TransferStatus1 = FAILED;  //状态测试
/**************延时函数*******************/
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
void Delay(__IO uint32_t nCount);
TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
char *int_to_string(int number,char *strnum)//整形数据转换为字符型
int j=0,i=0,n=0;
char temp;
while(number>0)
*(strnum+j)=number%10+48;
j++;
number=number/10;
n++;
for(i=0;iLibraries->Small printf
     set to 'Yes') calls __io_putchar() */
#else
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  return ch;
  while (1)
#endif
2015-01-06 21:13:56     打赏
24楼
帖子编辑的不错,有点赶工啊
