前期工作在“16号同学的作业本”,链接在此:
http://forum.eepw.com.cn/thread/260879/5/#43
任务目标:
在串口调试助手向STM32发送数据,控制LED流水等循环闪烁的速率。
发送格式:
data=n 即相邻两个LED的闪烁间隔为n毫秒,n的范围是1~9999。
完成进度:
led1~led8的初始状态为循环闪烁,一边闪烁一边等待中断;
通过串口发送data=n,使相邻的两个LED闪烁间隔为n毫秒,以此速率8个LED循环闪烁3轮后又全部熄灭,等待下一次发送的新数据。
疑难:
1.主函数以一个while(1)的循环,一边循环点亮led1~led8,一边等待中断,但是第一次的中断函数执行完以后(即led1~led8以n毫秒为间隔时间闪烁3轮),程序没有继续回到主函数的while(1)循环点亮led1~led8,这是为什么?
2.我目前只能让流水灯循环闪烁有限次,完成有限次的循环后,才能执行新来的中断。有没有办法让led闪烁速率保持在n毫秒的状态下接收新的中断,再保持新的闪烁速率……以此循环 ?
视频地址:http://player.youku.com/player.php/sid/XODIzMDY2MDMy/v.swf
代码如下:
#include "stm32f10x.h"
#include "stm32_eval.h"
#include "stdio.h"
#include "math.h"
#define buff_size 16;
char rx_buff[], rx_buff_count=0;
//static unsigned int sum;//静态局部变量sum
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
void RCC_Configuration(void)
RCC_DeInit();
RCC_HSICmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
RCC_HSEConfig(RCC_HSE_OFF);
RCC_LSEConfig(RCC_LSE_OFF);
RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
RCC_ADCCLKConfig(RCC_PCLK2_Div4);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣器
void GPIO_INIT()
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能PC时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//PC0-PC7
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽输出
GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化PC
void USART_int(long BaudRate)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能PA USART1
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;//TX位于PA9
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //推挽输出
GPIO_Init(GPIOA, &GPIO_InitStructure);//TX初始化 PA9
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//RX位于PA10
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//悬空输入
GPIO_Init(GPIOA, &GPIO_InitStructure);//RX初始化 PA10
/* USARTx configured as follow:
- BaudRate = 115200 baud
- Word Length = 8 Bits
- One Stop Bit
- No parity
- Hardware flow control disabled (RTS and CTS signals)
- Receive and transmit enabled
USART_InitStructure.USART_BaudRate = BaudRate;//传输速率
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长8比特
USART_InitStructure.USART_StopBits = USART_StopBits_1;//停止位1
USART_InitStructure.USART_Parity = USART_Parity_No;//
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//流控位none
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收和发送模式
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
USART_ClockInit(USART1, &USART_ClockInitStructure);//初始化USART1时钟
USART_Init(USART1, &USART_InitStructure);//初始化USART1
USART_Cmd(USART1, ENABLE);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
/* Configure four bit for preemption priority */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);//优先级
/* Enable the USART1 Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //选择USART1中断通道
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);//初始化中断
/*delay_us*/
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
/*delay_ms*/
void delay_ms(u32 n)
while(n--)
delay_us(1000);
void led_on_2(unsigned int sum) //led循环闪烁3次
int i;char j;
GPIO_SetBits(GPIOC,0x000000ff);
for(j=0;j<3;j++)
for(i=0x00000080;i!=0x00000000;)//LED
GPIO_ResetBits(GPIOC,i);//
delay_ms(50);
GPIO_SetBits(GPIOC,i);//
delay_ms(sum); //
i>>=1;
void USART_SendStr(char *str)//发送字符串
while((*str)!='\0')//到字符串的末尾才停止发送数据
USART_SendData(USART1,*str++);
while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
unsigned int translate(char *S,char j)//将字符串组成的数字转换成整型数据
unsigned int a[4],result=0;
char i;
for(i=0;i");
int main(void)
int i=0x00000080;
RCC_Configuration();
GPIO_INIT();
USART_int(9600);
USART_SendStr("SyStem booting......\r\n");//
USART_SendStr("\n>");//
GPIO_SetBits(GPIOC,0x000000ff);//LED
while(1)//LED循环闪烁
delay_ms(90);
i>>=1;
if(i==0x00000001){i=0x00000080;}
void USART1_IRQHandler(void)
while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)
if(USART_ReceiveData(USART1)==0x0d)//如果输入完毕,按下了回车
{input_ASK();}
else
USART_SendData(USART1,USART_ReceiveData(USART1));
rx_buff[rx_buff_count]= USART_ReceiveData(USART1);
rx_buff_count++;
USART_ClearFlag(USART1, USART_FLAG_RXNE);
