电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 5美金的cortex-a8,am335x来了!
共6条 1/1 1 跳转至页
2015-08-04 16:53:54     打赏
关键词: cortex-a8     am335x
2015-08-05 22:02:26     打赏
我们早就做出来板了!
2015-08-05 22:02:59     打赏
U-Boot 2014.04-rc2 (Aug 04 2015 - 15:32:20)
I2C:   ready
DRAM:  512 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Net:   cpsw
Hit any key to stop autoboot:  0
1152054 bytes read in 75 ms (14.6 MiB/s)
mmc1(part 0) is current device
SD/MMC found on device 1
reading uEnv.txt
105 bytes read in 4 ms (25.4 KiB/s)
Loaded environment from uEnv.txt
Importing environment from mmc ...
reading uImage
4156576 bytes read in 257 ms (15.4 MiB/s)
reading com335x-emmc.dtb
32925 bytes read in 8 ms (3.9 MiB/s)
## Booting kernel from Legacy Image at 81000000 ...
   Image Name:   Linux-3.14.43-g875c69b
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4156512 Bytes = 4 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 82000000
   Booting using the fdt blob at 0x82000000
   Loading Kernel Image ... OK
   Loading Device Tree to 9fb4a000, end 9fb5509c ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 3.14.43-g875c69b (Vic@EAC) (gcc version 4.7.3 20130
226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2
013.03) ) #25 Mon Aug 3 15:50:42 CST 2015
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio
n cache
[    0.000000] Machine model: TI AM335x com335x
[    0.000000] cma: CMA: reserved 24 MiB at 9e000000
[    0.000000] Memory policy: Data cache writeback
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pag
es: 129792
[    0.000000] Kernel command line: console=ttyO0,115200n8 tty0 noinitrd root=/d
ev/mmcblk0p2 rw rootfstype=ext4 rootwait lcdtype=AUO_AT070TN94 consoleblank=0
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 485448K/523264K available (5507K kernel code, 271K rwdata
, 2260K rodata, 252K init, 227K bss, 37816K reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc079e0c4   (7769 kB)
[    0.000000]       .init : 0xc079f000 - 0xc07de3b4   ( 253 kB)
[    0.000000]       .data : 0xc07e0000 - 0xc0823ce0   ( 272 kB)
[    0.000000]        .bss : 0xc0823ce0 - 0xc085cb80   ( 228 kB)
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrup
ts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 17895
6969942ns
[    0.000036] OMAP clocksource: timer1 at 24000000 Hz
[    0.000308] Console: colour dummy device 80x30
[    0.000336] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
[    0.089424] pid_max: default: 32768 minimum: 301
[    0.089527] Security Framework initialized
[    0.089585] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.089595] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.096549] CPU: Testing write buffer coherency: ok
[    0.096958] Setting up static identity map for 0x80566360 - 0x805663b8
[    0.097947] devtmpfs: initialized
[    0.099995] VFP support v0.3: implementor 41 architecture 3 part 30 variant c
 rev 3
[    0.106979] omap_hwmod: tptc0 using broken dt data from edma
[    0.107061] omap_hwmod: tptc1 using broken dt data from edma
[    0.107133] omap_hwmod: tptc2 using broken dt data from edma
[    0.111304] omap_hwmod: debugss: _wait_target_disable failed
[    0.166683] pinctrl core: initialized pinctrl subsystem
[    0.167754] regulator-dummy: no parameters
[    0.170299] NET: Registered protocol family 16
[    0.172368] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.174980] cpuidle: using governor ladder
[    0.174996] cpuidle: using governor menu
[    0.181466] syscon 44e10000.control_module: regmap [mem 0x44e10000-0x44e107fb
] registered
[    0.182925] platform 49000000.edma: alias fck already exists
[    0.182948] platform 49000000.edma: alias fck already exists
[    0.182963] platform 49000000.edma: alias fck already exists
[    0.184109] OMAP GPIO hardware version 0.1
[    0.199319] No ATAGs?
[    0.199340] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.224863] bio: create slab <bio-0> at 0
[    0.241055] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[    0.242096] vmmcsd_fixed: 3300 mV
[    0.245251] vgaarb: loaded
[    0.245790] i2c-core: driver [palmas] using legacy suspend method
[    0.245800] i2c-core: driver [palmas] using legacy resume method
[    0.246531] SCSI subsystem initialized
[    0.248036] usbcore: registered new interface driver usbfs
[    0.248224] usbcore: registered new interface driver hub
[    0.248419] usbcore: registered new device driver usb
[    0.249457] omap_i2c 44e0b000.i2c: could not find pctldev for node /pinmux@44
e10800/pinmux_i2c0_pins, deferring probe
[    0.249486] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral
[    0.249897] pps_core: LinuxPPS API ver. 1 registered
[    0.249909] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome
tti <giometti@linux.it>
[    0.250045] PTP clock support registered
[    0.252050] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.252969] Advanced Linux Sound Architecture Driver Initialized.
[    0.254692] Switched to clocksource timer1
[    0.274119] NET: Registered protocol family 2
[    0.275154] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.275209] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.275255] TCP: Hash tables configured (established 4096 bind 4096)
[    0.275331] TCP: reno registered
[    0.275343] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.275361] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.275545] NET: Registered protocol family 1
[    0.275938] RPC: Registered named UNIX socket transport module.
[    0.275951] RPC: Registered udp transport module.
[    0.275957] RPC: Registered tcp transport module.
[    0.275964] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.277144] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counter
s available
[    0.279942] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.443192] VFS: Disk quotas dquot_6.5.2
[    0.443261] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.443787] NFS: Registering the id_resolver key type
[    0.443868] Key type id_resolver registered
[    0.443878] Key type id_legacy registered
[    0.443933] msgmni has been set to 996
[    0.445486] NET: Registered protocol family 38
[    0.445532] io scheduler noop registered
[    0.445540] io scheduler deadline registered
[    0.445562] io scheduler cfq registered (default)
[    0.447325] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    0.453794] omap_uart 44e09000.serial: no wakeirq for uart0
[    0.453949] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88, base_baud =
3000000) is a OMAP UART0
[    1.080853] console [ttyO0] enabled
[    1.085219] omap_uart 48022000.serial: no wakeirq for uart0
[    1.091168] 48022000.serial: ttyO1 at MMIO 0x48022000 (irq = 89, base_baud =
3000000) is a OMAP UART1
[    1.101492] omap_uart 48024000.serial: no wakeirq for uart0
[    1.107509] 48024000.serial: ttyO2 at MMIO 0x48024000 (irq = 90, base_baud =
3000000) is a OMAP UART2
[    1.117733] omap_uart 481a6000.serial: no wakeirq for uart0
[    1.123669] 481a6000.serial: ttyO3 at MMIO 0x481a6000 (irq = 60, base_baud =
3000000) is a OMAP UART3
[    1.133950] omap_uart 481a8000.serial: no wakeirq for uart0
[    1.139965] 481a8000.serial: ttyO4 at MMIO 0x481a8000 (irq = 61, base_baud =
3000000) is a OMAP UART4
2015-08-05 22:03:58     打赏
2015-08-05 22:04:48     打赏
完全兼容狗板的,beagle bone black,需要的找我!qq:259134942
2015-08-11 15:27:12     打赏
这板子做的不错,我们的也不赖
有需求的朋友加这个扣扣:3247613929
共6条 1/1 1 跳转至页
