ubuntu16.04 make menuconfig时出现fatal error: curses.h: No such file or directory 说明此时没有安装以下文件
sudo apt-get install libncurses5-dev libncursesw5-dev
说明:
The ncurses library routines are a terminal-independent method of updating character screens with reasonable optimization.
This package contains the header files, static libraries and symbolic links that developers using ncursesw will need.
This package includes support for wide characters.
之后就可make menuconfig了
