RSA的原理这篇文章介绍的比较好:
根据介绍写了下面的代码:
#include "stdio.h"
#include "stdlib.h"
#include "string.h"
static int rsa_check_prime_number(unsigned int n)
unsigned int i = 0;
if(n < 1)
return -1;
for(i = 2;i < n;i++)
if((n % i) == 0)
return -1;
return 0;
int rsa_create_key()
unsigned int prime_number1, prime_number2;
unsigned int euler_n;
unsigned int prime_number_e, prime_number_d, multiply_n;
unsigned int i = 0;
printf("enter two prime numbers: number1,number2\n\r");
scanf("%d,%d", &prime_number1, &prime_number2);
if(0 != rsa_check_prime_number(prime_number1) || 0 != rsa_check_prime_number(prime_number2))
printf("number invalid...\n\r");
return -1;
multiply_n = prime_number1 * prime_number2;
euler_n = (prime_number1 - 1) * (prime_number2 - 1);
printf("two prime numbers:%d , %d, %d , %d\n\r", prime_number1, prime_number2, multiply_n, euler_n);
printf("select a prime number between 1 and %d :\n\r", euler_n);
scanf("%d", &prime_number_e);
for(i = 0;i < euler_n;i++)
if((i * prime_number_e - 1) % euler_n == 0)
break;
if(i >= euler_n)
return -1;
prime_number_d = i;
printf("public: %d, %d\n\r",multiply_n, prime_number_e);
printf("private: %d, %d\n\r",multiply_n, prime_number_d);
return 0;
typedef struct
unsigned int rsa_p;
unsigned int rsa_e;
unsigned int rsa_d;
}rsa_factor_t;
static rsa_factor_t rsa_factor;
int rsa_set_public_key(unsigned int common_p, unsigned int public_e)
rsa_factor.rsa_p = common_p;
rsa_factor.rsa_e = public_e;
printf("rsa_p:%d, rsa_e:%d\n\r", rsa_factor.rsa_p, rsa_factor.rsa_e);
return 0;
int rsa_set_private_key(unsigned int common_p, unsigned int private_d)
rsa_factor.rsa_d = private_d;
printf("rsa_p:%d, rsa_d:%d\n\r", rsa_factor.rsa_p, rsa_factor.rsa_d);
return 0;
int rsa_encrypt(unsigned char *text , unsigned char *buff, unsigned int len)
unsigned int i = 0, j = 0, c = 0, tmp_c = 0;
if(buff == NULL)
printf("buff invalid !\n\r");
return -1;
for(i = 0;i < len;i++)
tmp_c = text[i];
c = text[i];
for(j = 1; j < rsa_factor.rsa_e; j++)
tmp_c = (tmp_c * c) % rsa_factor.rsa_p;
((unsigned int *)buff)[i] = tmp_c;
return (i * sizeof(unsigned int));
int rsa_decrypt(unsigned char *text, unsigned char *buff, unsigned int len)
unsigned int i = 0, j = 0;
unsigned long long int c = 0, tmp_c = 0;
if(buff == NULL)
return -1;
for(i = 0;i < (len / sizeof(int));i++)
tmp_c = ((unsigned int *)text)[i];
for(j = 1; j < rsa_factor.rsa_d; j++)
buff[i] = (unsigned char)(tmp_c & 0xff);
return i;
int main()
unsigned char sel = 1;
unsigned int key_1, key_2;
unsigned char tmp_buf[128];
unsigned char rsa_buf[128];
unsigned int i = 0, count = 0;
printf("*********************************************\n\r");
printf("******RSA encryption and decryption *********\n\r");
while(1)
printf("***1. create public and private key \n\r");
printf("***2. data encryption \n\r");
printf("***3. data decryption \n\r");
printf("***enter number : \n\r");
scanf("%d", &sel);
if(sel < 1 || sel > 3)
continue;
switch(sel)
case 1:
if(0 != rsa_create_key())
printf("fail to create key ... \n\r");
break;
case 2:
printf("set public key: common_p,rsa_e\n\r");
scanf("%d,%d", &key_1, &key_2);
rsa_set_public_key(key_1, key_2);
printf("enter your information: \n\r");
scanf("%s", (char *)tmp_buf);
count = strlen((char *)tmp_buf);
count = rsa_encrypt(tmp_buf, rsa_buf, count);
printf("::::\n\r");
for(i = 0;i < count;i++)
printf("%d ", rsa_buf[i]);
printf("\n\r");
break;
case 3:
printf("set private key: common_p,rsa_d\n\r");
rsa_set_private_key(key_1, key_2);
printf("enter your data len: \n\r");
scanf("%d", &count);
printf("please enter %d numbers: \n\r", count);
for(i = 0;i < count; i++)
scanf("%d", &rsa_buf[i]);
printf("::::\n\r");
count = rsa_decrypt(rsa_buf, tmp_buf, count);
for(i = 0;i <= count;i++)
printf("%c", tmp_buf[i]);
printf("\n\r");
break;
default:
break;
}试了运行了一下,好像是可以的:
创建密钥:
用公共密钥加密"EEPW"
得到16个数据然后用私有密钥解密:
大家可以玩玩
收藏!收藏!
