题意:判断一棵树是否是二叉搜索树;
思路:中序遍历看是否是有序的
class Solution
public:
bool isValidBST(TreeNode* root)
int pre = INT_MIN;
bool res = true;
inorder(pre, root, res);
return res;
void inorder(int& pre, TreeNode* root, bool &res)
if (root)
inorder(pre, root->left, res);
if (root->val<=pre)
res = false;
return;
pre = root->val;
inorder(pre, root->right, res);
