Given a string S and a string T, count the number of distinct subsequences ofT in S.
A subsequence of a string is a new string which is formed from the original string by deleting some (can be none) of the characters without disturbing the relative positions of the remaining characters. (ie,"ACE"is a subsequence of"ABCDE"while"AEC"is not).
Here is an example:
S ="rabbbit", T ="rabbit"
Return3.
思路:动态规划思想
dp[i][j]表示S中前i个字符构成的字符串包含T中前j个字符构成的字符串的长度,
当s[i-1]==T[j-1]时,则新的dp值可以说不使用第i个字符,却能构成T中j子串
class Solution {
public:
int numDistinct(string S, string T)
int slen = S. length();
int tlen = T.length();
vector<vector<int>> dp;
vector<int> tmp(tlen+1, 0);
tmp[0] = 1;
for (int i=0; i<=slen; i++)
dp.push_back(tmp);
for (int i=1; i<=slen; i++)
for(int j=1; i<=tlen; j++)
if (S[i-1]==T[j-1])
dp[i][j] = dp[i-1][j] + dp[i-1][j-1];
else
dp[i][j] = dp[i-1][j];
return dp[slen][tlen];
