Given an array of integers, every element appears three times except for one. Find that single one.
Note:
Your algorithm should have a linear runtime complexity. Could you implement it without using extra memory?
思路:若一个数出现三次,则其对应的二进制数每一位相加必为3或者0。统计数组中元素的每一位,若为3的倍数,所求数的二进制位对3取余为0
否则为1
class Solution
public:
int singleNumber(int A[], int n)
int bit[32] = {0};
int res = 0;
for (int i=0; i<32; i++)
for (int j = 0; j < n; j++)
bit[i] += (A[j] >> i) & 1;
res |= (bit[i]%3)<<i;
return res;
