电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » evaluate-reverse-polish-notation
2018-02-02 13:15:43     打赏
Evaluate the value of an arithmetic expression in Reverse Polish Notation.
Valid operators are+,-,*,/. Each operand may be an integer or another expression.
Some examples:
  ["2", "1", "+", "3", "*"] -> ((2 + 1) * 3) -> 9
  ["4", "13", "5", "/", "+"] -> (4 + (13 / 5)) -> 6
题意:逆波兰应用,很明显要考察的是栈;要注意的是,就是新来的符号,将栈中两个值取出进行操作。再放回栈中。
此时先取出的num2,后取出的是num1;进行num1和num2的操作;
[cpp] view plain copy
  1. class Solution
  2. {
  3. public:
  4.     int evalRPN(vector<string> &tokens)
  5.     {
  6.         if (tokens.empty())
  7.         {
  8.             return 0;
  9.         }
  10.
  11.         stack<int> st;
  12.
  13.         for (int i=0; i<tokens.size(); i++)
  14.         {
  15.             string s = tokens[i];
  16.             if (s =="+" || s=="-"
  17.                 || s=="*" || s=="/")
  18.             {
  19.                 if (st.size()<2)
  20.                 {
  21.                     return 0;
  22.                 }
  23.                 int num2 = st.top();
  24.                 st.pop();
  25.
  26.                 int num1 = st.top();
  27.                 st.pop();
  28.                 int result = 0;
  29.
  30.                 if (s=="+")
  31.                 {
  32.                     result = num1 + num2;
  33.                 }
  34.                 if (s == "-")
  35.                 {
  36.                     result = num1 - num2;
  37.                 }
  38.                 if (s == "*")
  39.                 {
  40.                     result = num1 * num2;
  41.                 }
  42.                 if (s == "/")
  43.                 {
  44.                     result = num1 / num2;
  45.                 }
  46.
  47.                 st.push(result);
  48.             }
  49.             else
  50.             {
  51.                 st.push(atoi(s.c_str()));
  52.             }
  53.         }
  54. return st.top();
  55.
  56.     }
  57. };
