电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » Minimum Depth of Binary Tree
2018-02-02 13:16:19     打赏
Given a binary tree, find its minimum depth.The minimum depth is the number of nodes along the shortest path from the root node down to the nearest leaf node.
题意:求最小路径。
方法一:递归
[cpp] view plain copy
  1. class Solution
  2. {
  3. public:
  4.     int run(TreeNode* root)
  5.     {
  6.         if (root==NULL)
  7.         {
  8.             return 0;
  9.         }
  10.
  11.         int left = run(root->left);
  12.         int right = run(root->right);
  13.
  14.         return 1 + min(left,right);
  15.     }
  16. };
方法二:非递归,采用层次遍历,如果该层有叶子节点,那么最短depth到此为止,如果没有,继续遍历下一层
  1. class Solution
  2. {
  3. public:
  5.     {
  6.         if(root==NULL)
  7.         {
  8.             return 0;
  9.         }
  10.
  11.         if (root->left == NULL && root->right == NULL)
  12.         {
  13.             return 1;
  14.         }
  15.
  16.         int depth = 0;
  17.         queue<TreeNode*> qu;
  18.         qu.push(root);
  19.
  20.         while (!qu.empty())
  21.         {
  22.             int len = qu.size();
  23.             depth++;
  24.
  25.             for (int i = 0; i<len; i++)
  26.             {
  27.                 TreeNode* cur = qu.front();
  28.                 qu.pop();
  29.                 if (cur->left == NULL && cur->right == NULL)
  30.                 {
  31.                     return depth;
  32.                 }
  33.
  34.                 if (cur->left != NULL)
  35.                 {
  36.                     qu.push(cur->left);
  37.                 }
  38.                 if (cur->right != NULL)
  39.                 {
  40.                     qu.push(cur->right);
  41.                 }
  42.             }
  43.         }
  44.
  45.     }
  46. };
