电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » Micropython TPYBoard I2C的用法
2018-05-25 11:14:34     打赏
先看看基本用法:
    from pyb import I2C    i2c = I2C(1)                         # create on bus 1    i2c = I2C(1, I2C.MASTER)             # create and init as a master    i2c.init(I2C.MASTER, baudrate=20000) # init as a master    i2c.init(I2C.SLAVE, addr=0x42)       # init as a slave with given address    i2c.deinit()                         # turn off the peripheral    i2c.init(I2C.MASTER)    i2c.send('123', 0x42)        # send 3 bytes to slave with address 0x42    i2c.send(b'456', addr=0x42)  # keyword for address    i2c.is_ready(0x42)           # check if slave 0x42 is ready    i2c.scan()                   # scan for slaves on the bus, returning    #   a list of valid addresses    i2c.mem_read(3, 0x42, 2)     # read 3 bytes from memory of slave 0x42,    #   starting at address 2 in the slave    i2c.mem_write('abc', 0x42, 2, timeout=1000) # write 'abc' (3 bytes) to memory of slave 0x42    # starting at address 2 in the slave, timeout after 1 second   I2C的用法:
class pyb.I2C(bus, ...)bus,I2C总线的序号i2c.deinit(),解除I2C定义i2c.init(mode, *, addr=0x12, baudrate=400000, gencall=False),初始化mode,只能是 I2C.MASTER 或 I2C.SLAVEaddr,7位I2C地址baudrate,时钟频率gencall,通用调用模式i2c.is_ready(addr),检测I2C设备是否响应,只对主模式有效i2c.mem_read(data, addr, memaddr, *, timeout=5000, addr_size=8),读取数据data,整数或者缓存addr,设备地址memaddr,内存地址timeout,读取等待超时时间addr_size,memaddr的大小。8位或16位i2c.mem_write(data, addr, memaddr, *, timeout=5000, addr_size=8),写入数据,参数含义同上i2c.recv(recv, addr=0x00, *, timeout=5000),从总线读取数据recv,需要读取数据数量,或者缓冲区addr,I2C地址timeout,超时时间i2c.send(send, addr=0x00, *, timeout=5000)send,整数或者缓冲区addr,I2C地址timeout,超时时间i2c.scan(),搜索I2C总线上设备。
管理员
2018-05-25 12:30:52     打赏
谢谢楼主分享
