new Thread(){
public void run() {
//System.out.println("init-66666666662----");
view.loadUrl(url);
}.start();
在新的线程中操作 WebView会报错
04-26 14:52:22.645: E/AndroidRuntime(7635): java.lang.RuntimeException: java.lang.Throwable: A WebView method was called on thread 'Thread-666'. All WebView methods must be called on the same thread. (Expected Looper Looper (main, tid 1) {35b6f8e5} called on null, FYI main Looper is Looper (main, tid 1) {35b6f8e5})
是因为 新版的Android的SDK要求在创建WebView所在的线程中操作它,在其它线程中操作它都会报这样的错误。
解决方法
WebViewActivity.this.runOnUiThread(new Runnable() {//其中 WebViewActivity 是webview所在的Activity
public void run() {
webview.loadUrl(url);
