基本功能描述
通过单片机控制8个LED指示灯按照特定的顺序(工作模式)亮灭;指示灯的流转间隔可通过按键调整,亮度可由电位器RB2进行控制;各工作模式的流转间隔时间需在E2PROM中保存,并可在硬件重新上电后,自动载入。
下面附上部分程序:
#include "iic.h"
unsigned char code smgduan[]={0XC0,0XF9,0XA4,0XB0,0X99,0X92,0X82,0XF8,0X80,0X90,0XBF,0XFF};
unsigned char code Mode[32]={0XFE,0XFD,0XFB,0XF7,0XEF,0XDF,0XBF,0X7F,//0,1,2,3,4,5,6,7 模式1
0X7F,0XBF,0XDF,0XEF,0XF7,0XFB,0XFD,0XFE,//8,9,10,11,12,13,14,15 模式2
0X7E,0XBD,0XDB,0XE7,0X7E,0XBD,0XDB,0XE7,//16,17,18,19,20,21,22,23 模式3
0XE7,0XDB,0XBD,0X7E,0XE7,0XDB,0XBD,0X7E};//24,25,26,27,28,29,30,31 模式4
unsigned char yi,er,san,si,wu,liu,qi,ba,duan[8],SMG;
unsigned char RD2,Flag,brightness,choose,Run;
unsigned char Start,num=1,jia,jian,level;
unsigned int tt,yy,Interval=400;
unsigned char P30_S7,P31_S6,P32_S5,P33_S4;
void Delay1ms(unsigned int ms);
void Display1();
void Display2();
void Timer0Init(void); //1微秒@11.0592MHz
void ledCtr(unsigned char per);//RB2控制LED灯亮度
void Key_Scan();
void GongNeng();
void EEPROM_Storage();//储存到EEPROM
void EEPROM_Gain();//读取EEPROM
void allInit();
void main()
allInit();
Timer0Init();
EEPROM_Gain();
while(1)
GongNeng();
Key_Scan();
RD2=IIC_Read(0X03)*0.02;
void allInit()
P2=0XA0;
P0=0X00;//关闭蜂鸣器,继电器
P2=0X80;
P0=0XFF;//关闭LED灯
P2=0XC0;
P0=0XFF;//选择所有数码管
P2=0XFF;
P0=0XFF;//关闭所有数码管
void Delay1ms(unsigned int ms) //@11.0592MHz
int i,j;
for(i=ms;i>0;i--)
for(j=845;j>0;j--);
void Display1()
unsigned char a;
for(a=0;a<8;a++)
P2=0XC0;
P0=1<<a;
P2=0XFF;
P0=duan[a];
Delay1ms(2);
P2=0XC0;//消隐
P0=0XFF;
P2=0XFF;
P0=0XFF;
void Display2()
duan[0] = smgduan[yi];
duan[1] = smgduan[er];
duan[2] = smgduan[san];
duan[3] = smgduan[si];
duan[4] = smgduan[wu];
duan[5] = smgduan[liu];
duan[6] = smgduan[qi];
duan[7] = smgduan[ba];
void Timer0Init(void) //1微秒@11.0592MHz
AUXR |= 0x80; //定时器时钟1T模式
TMOD &= 0xF0; //设置定时器模式
TL0 = 0xCD; //设置定时初值
TH0 = 0xD4; //设置定时初值
TF0 = 0; //清除TF0标志
TR0 = 1; //定时器0开始计时
ET0 = 1;
EA = 1;
void Timer0() interrupt 1
tt++;
if(tt==800) { Flag++; tt=0; }
if(Flag==10) { Flag=0; }
yy++;
if(yy==Interval) { Run++; yy=0; }
if(Run==8) { Run=0; }
void ledCtr(unsigned char per)//RB2控制LED灯亮度
unsigned char i=1;
for(i=1;i<=100;i++)
P2=0X80;
if(i<per) { P0=Mode[(num-1)*8+Run]; }
else { P2=0X80;P0=0XFF; }//关闭灯
void Key_Scan()
if(P30==0) { P30_S7=1; }
if(P31==0) { P31_S6=1; }
if(P32==0) { P32_S5=1; }
if(P33==0) { P33_S4=1; }
if((P30_S7==1)&&(P30==1))//S7
if(choose==0)
if(Start==0) { Start=1; Run=0; yy=0; }
else if(Start==1) { Start=0; }
SMG=0;
P30_S7=0;
if((P31_S6==1)&&(P31==1))//S6
if(Start==0)
if(choose==0) { choose=1; SMG=1; }
else if(choose==1) { choose=2; SMG=1; }
else if(choose==2) { choose=0; SMG=0; EEPROM_Storage(); }
P31_S6=0;
if((P32_S5==1)&&(P32==1))//S5
if(choose!=0) { jia=1; }
P32_S5=0;
if((P33_S4==1)&&(P33==1))//S4
if(choose!=0) { jian=1; }
P33_S4=0;
void GongNeng()
if(SMG==1)
Display1();
Display2();
if(choose==1)
yi=10;san=10;si=11;
if(Flag%2==0) { er=num; }
else if(Flag%2==1) { er=11; }
if(Interval/1000==0) { wu=11; }
else { wu=Interval/1000; }
liu=Interval%1000/100;qi=Interval%100/10;ba=Interval%10;
if(choose==2)
yi=10;er=num;san=10;si=11;
if(Flag%2==0)
else if(Flag%2==1)
{ wu=11;liu=11;qi=11;ba=11; }
if((choose==0)&&(P33_S4==1))
Display1();
Display2();
yi=11;er=11;san=11;si=11;wu=11;liu=11;qi=10;ba=level;
if(Start==0) { P2=0X80;P0=0XFF; }
else if(Start==1) { ledCtr(brightness); }
if(jia==1)
jia=0;
if(choose==1)
num++;
if(num==5) { num=1; }
if(choose==2)
Interval=Interval+100;
if(Interval==1300) { Interval=400; }
if(jian==1)
jian=0;
if(choose==1)
num--;
if(num==0) { num=4; }
if(choose==2)
Interval=Interval-100;
if(Interval==300) { Interval=1200; }
if(RD2<=1.25) { level=1; brightness=25; }
else if((1.25<RD2)&&(RD2<=2.5)) { level=2; brightness=50; }
else if((2.5<RD2)&&(RD2<=3.75)) { level=3; brightness=75; }
else if((3.75<RD2)&&(RD2<=5)) { level=4; brightness=100; }
void EEPROM_Storage()//储存到EEPROM
unsigned char high,low;
high=Interval/256;
low=Interval%256;
EEPROM_Write(0X01,high);
Delay1ms(1);
EEPROM_Write(0X02,low);
Delay1ms(1);
EEPROM_Write(0X03,num);
void EEPROM_Gain()//读取EEPROM
high=EEPROM_Read(0X01);
Delay1ms(1);
low=EEPROM_Read(0X02);
Delay1ms(1);
num=EEPROM_Read(0X03);
Interval=high*256+low;
}完整程序及试题文件请移步百度网盘:
链接:https://pan.baidu.com/s/1wskPcpl6hurRR_TiUiBTsQ
提取码:g9b4
