电子产品世界 » 论坛首页 » 高校专区 » 坤创E-Geek/天科大新电社 » 蓝桥杯大赛单片机开发与设计第九届省赛试题--彩灯控制器
共5条 1/1 1 跳转至页
2019-03-02 10:53:30     打赏
基本功能描述
       通过单片机控制8个LED指示灯按照特定的顺序(工作模式)亮灭;指示灯的流转间隔可通过按键调整,亮度可由电位器RB2进行控制;各工作模式的流转间隔时间需在E2PROM中保存,并可在硬件重新上电后,自动载入。
下面附上部分程序:
#include "iic.h"
unsigned char code smgduan[]={0XC0,0XF9,0XA4,0XB0,0X99,0X92,0X82,0XF8,0X80,0X90,0XBF,0XFF};
unsigned char code Mode[32]={0XFE,0XFD,0XFB,0XF7,0XEF,0XDF,0XBF,0X7F,//0,1,2,3,4,5,6,7  模式1
               0X7F,0XBF,0XDF,0XEF,0XF7,0XFB,0XFD,0XFE,//8,9,10,11,12,13,14,15   模式2
               0X7E,0XBD,0XDB,0XE7,0X7E,0XBD,0XDB,0XE7,//16,17,18,19,20,21,22,23 模式3
               0XE7,0XDB,0XBD,0X7E,0XE7,0XDB,0XBD,0X7E};//24,25,26,27,28,29,30,31 模式4
unsigned char yi,er,san,si,wu,liu,qi,ba,duan[8],SMG;
unsigned char RD2,Flag,brightness,choose,Run;
unsigned char Start,num=1,jia,jian,level;
unsigned int tt,yy,Interval=400;
unsigned char P30_S7,P31_S6,P32_S5,P33_S4;
void Delay1ms(unsigned int ms);
void Display1();
void Display2();
void Timer0Init(void);  //1微秒@11.0592MHz
void ledCtr(unsigned char per);//RB2控制LED灯亮度
void Key_Scan();
void GongNeng();
void EEPROM_Storage();//储存到EEPROM
void EEPROM_Gain();//读取EEPROM
void allInit();
void main()
 allInit();
 Timer0Init();
 EEPROM_Gain();
 while(1)
  GongNeng();
  Key_Scan();
  RD2=IIC_Read(0X03)*0.02;
void allInit()
 P2=0XA0;
 P0=0X00;//关闭蜂鸣器,继电器
 P2=0X80;
 P0=0XFF;//关闭LED灯
 P2=0XC0;
 P0=0XFF;//选择所有数码管
 P2=0XFF;
 P0=0XFF;//关闭所有数码管
void Delay1ms(unsigned int ms)  //@11.0592MHz
 int i,j;
 for(i=ms;i>0;i--)
  for(j=845;j>0;j--);
void Display1()
 unsigned char a;
 for(a=0;a<8;a++)
  P2=0XC0;
  P0=1<<a;
  P2=0XFF;
  P0=duan[a];
  Delay1ms(2);
 P2=0XC0;//消隐
 P0=0XFF;
 P2=0XFF;
 P0=0XFF;
void Display2()
 duan[0] = smgduan[yi];
 duan[1] = smgduan[er];
 duan[2] = smgduan[san];
 duan[3] = smgduan[si];
 duan[4] = smgduan[wu];
 duan[5] = smgduan[liu];
 duan[6] = smgduan[qi];
 duan[7] = smgduan[ba];
void Timer0Init(void)  //1微秒@11.0592MHz
 AUXR |= 0x80;  //定时器时钟1T模式
 TMOD &= 0xF0;  //设置定时器模式
 TL0 = 0xCD;  //设置定时初值
 TH0 = 0xD4;  //设置定时初值
 TF0 = 0;  //清除TF0标志
 TR0 = 1;  //定时器0开始计时
 ET0 = 1;
 EA = 1;
void Timer0() interrupt 1
 tt++;
 if(tt==800) { Flag++; tt=0; }
 if(Flag==10) { Flag=0; }
 yy++;
 if(yy==Interval) { Run++; yy=0; }
 if(Run==8) { Run=0; }
void ledCtr(unsigned char per)//RB2控制LED灯亮度
 unsigned char i=1;
 for(i=1;i<=100;i++)
  P2=0X80;
  if(i<per) { P0=Mode[(num-1)*8+Run]; }
  else { P2=0X80;P0=0XFF; }//关闭灯
void Key_Scan()
 if(P30==0) { P30_S7=1; }
 if(P31==0) { P31_S6=1; }
 if(P32==0) { P32_S5=1; }
 if(P33==0) { P33_S4=1; }
 if((P30_S7==1)&&(P30==1))//S7
  if(choose==0)
   if(Start==0) { Start=1; Run=0; yy=0; }
   else if(Start==1) { Start=0; }
   SMG=0;
  P30_S7=0;
 if((P31_S6==1)&&(P31==1))//S6
  if(Start==0)
   if(choose==0) { choose=1; SMG=1; }
   else if(choose==1) { choose=2; SMG=1; }
   else if(choose==2) { choose=0; SMG=0; EEPROM_Storage(); }
  P31_S6=0;
 if((P32_S5==1)&&(P32==1))//S5
  if(choose!=0) { jia=1; }
  P32_S5=0;
 if((P33_S4==1)&&(P33==1))//S4
  if(choose!=0) { jian=1; }
  P33_S4=0;
void GongNeng()
 if(SMG==1)
  Display1();
  Display2();
  if(choose==1)
   yi=10;san=10;si=11;
   if(Flag%2==0) { er=num; }
   else if(Flag%2==1) { er=11; }
   if(Interval/1000==0) { wu=11; }
   else { wu=Interval/1000; }
   liu=Interval%1000/100;qi=Interval%100/10;ba=Interval%10;
  if(choose==2)
   yi=10;er=num;san=10;si=11;
   if(Flag%2==0)
   else if(Flag%2==1)
   { wu=11;liu=11;qi=11;ba=11; }
 if((choose==0)&&(P33_S4==1))
  Display1();
  Display2();
  yi=11;er=11;san=11;si=11;wu=11;liu=11;qi=10;ba=level;
 if(Start==0) { P2=0X80;P0=0XFF; }
 else if(Start==1) { ledCtr(brightness); }
 if(jia==1)
  jia=0;
  if(choose==1)
   num++;
   if(num==5) { num=1; }
  if(choose==2)
   Interval=Interval+100;
   if(Interval==1300) { Interval=400; }
 if(jian==1)
  jian=0;
  if(choose==1)
   num--;
   if(num==0) { num=4; }
  if(choose==2)
   Interval=Interval-100;
   if(Interval==300) { Interval=1200; }
 if(RD2<=1.25) { level=1; brightness=25; }
 else if((1.25<RD2)&&(RD2<=2.5)) { level=2; brightness=50; }
 else if((2.5<RD2)&&(RD2<=3.75)) { level=3; brightness=75; }
 else if((3.75<RD2)&&(RD2<=5)) { level=4; brightness=100; }
void EEPROM_Storage()//储存到EEPROM
 unsigned char high,low;
 high=Interval/256;
 low=Interval%256;
 EEPROM_Write(0X01,high);
 Delay1ms(1);
 EEPROM_Write(0X02,low);
 Delay1ms(1);
 EEPROM_Write(0X03,num);
void EEPROM_Gain()//读取EEPROM
 high=EEPROM_Read(0X01);
 Delay1ms(1);
 low=EEPROM_Read(0X02);
 Delay1ms(1);
 num=EEPROM_Read(0X03);
 Interval=high*256+low;
完整程序及试题文件请移步百度网盘:
链接:https://pan.baidu.com/s/1wskPcpl6hurRR_TiUiBTsQ
提取码:g9b4
关键词: 蓝桥     单片机     竞赛     彩灯     控制器
2019-03-02 10:56:42     打赏
征集二维数组的方法;优化mode[32]数组。
2019-03-02 23:15:31     打赏
很不错,很棒!
管理员
2019-03-04 09:37:06     打赏
谢谢楼主分享
2019-03-07 20:55:36     打赏
楼主好棒
共5条 1/1 1 跳转至页
