共3条
请教:Intel的网络芯片82559和82559er之间的区别??
我在网上找到一点线索:
The 82559ER is a subset of the 82559. The feature the
82559ER misses in comparison to 82559:
- No CardBus and modem support, as the 82559 has a internel
PCMCIA/CardBus controller
- Some restriction in WOL
- New Device ID 1209 for 82559ER, I think 82559 has Device ID 1229
For a "normal" user, there is NO relevant differece between the
two chip derivates. The only point is, that chip ID of 1209
instead of the 1229, which often older drivers do not recognize.
For this I often patch the chip ID (for test purpose) or I add
the new ID to be tested from the driver.
意思是说有点差别,但对于一般的用户来说,只要将device id改了就可以了。唉,不知道是不是我的硬件有问题哦,毕竟是200来脚的BGA封装呀。。。
共3条
