【项目介绍】
使用RTT的i2c驱动OLED屏以及SHT30温湿度计,实现一个温湿度计。
【移植步骤】
1、打开移植工程NXP-MCXA153开发之三硬件i2c驱动ssd1306-电子产品世界论坛 (eepw.com.cn)
2、打开env图形配置工具,添加相sht3x的驱动。
设置路径为:RT-Thread online packages → peripheral libraries and drivers → sensors drivers
保存后重新使用以pkg --update下载在线的驱动库到工程。
再使用scons --target=mdk5重新生成工程。
3、把sht30的SDA与SCL与P3_28、P3_27接上。
4、添加代码如下:
#include <rtdevice.h>
#include "drv_pin.h"
#include "sht3x.h"
#include "ssd1306.h"
#define LED_PIN        ((3*32)+12)
	static sht3x_device_t sht3x_dev = RT_NULL;  //声明sht3x
	rt_uint8_t sht_addr = SHT3X_ADDR_PD ;       //定义从机地址
int main(void)
	char show_char[20];
#if defined(__CC_ARM)
    rt_kprintf("using armcc, version: %d\n", __ARMCC_VERSION);
#elif defined(__clang__)
    rt_kprintf("using armclang, version: %d\n", __ARMCC_VERSION);
#elif defined(__ICCARM__)
    rt_kprintf("using iccarm, version: %d\n", __VER__);
#elif defined(__GNUC__)
    rt_kprintf("using gcc, version: %d.%d\n", __GNUC__, __GNUC_MINOR__);
#endif
    rt_pin_mode(LED_PIN, PIN_MODE_OUTPUT);  /* Set GPIO as Output */
    rt_kprintf("MCXA153 HelloWorld\r\n");
		sht3x_dev = sht3x_init("i2c0",sht_addr);  //初始化sht3x
	  if(NULL == sht3x_dev)
			rt_kprintf("init sht3x failed\r\n");
		else
			rt_kprintf("init sht3x successed!\r\n");
		ssd1306_Init();
    while (1)
			ssd1306_Fill(Black);
			ssd1306_SetCursor(4, 0);
			ssd1306_WriteString("MCXA153Demo", Font_11x18, White);
			if (sht3x_dev)
					/* read the sensor data */
					sht3x_read_singleshot(sht3x_dev);
					rt_sprintf(show_char,"Hum:%d.%d",(int)sht3x_dev->humidity, (int)(sht3x_dev->humidity * 10) % 10);
					ssd1306_SetCursor(12, 20);
					ssd1306_WriteString(show_char, Font_11x18, White);
				  rt_sprintf(show_char,"Temp:%d.%d",(int)sht3x_dev->temperature, (int)(sht3x_dev->temperature * 10) % 10);
					ssd1306_SetCursor(2, 40);
			ssd1306_UpdateScreen();
        rt_pin_write(LED_PIN, PIN_HIGH);    /* Set GPIO output 1 */
        rt_thread_mdelay(500);               /* Delay 500mS */
        rt_pin_write(LED_PIN, PIN_LOW);     /* Set GPIO output 0 */
}代码主要的思路为初始化sht3x、ssd1306,然后读取温湿度值,通过ssd1306显示到OLED屏中。
【项目效果】
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
