电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » windml下的设计 各位高手请进....
共17条 2/2 ‹ 1 2 跳转至页
2005-05-18 22:37:00     打赏
11楼
谢谢两位。但运行的应该是工程所生成的vxworks.exe没错。我不知道怎么把WindML加进VxWorks内核。所以我选择的是下面的第三种方法,
To proceed with the tutorial, you may select one of the following: 1.Build a VxWorks image that includes the WindML object module. Using this technique, the VxWorks image includes all functionality so you can download and execute any WindML example program. 2. Dynamically download the WindML object module followed by the example program you desire to execute. 3. Dynamically download the example program pre-linked with the WindML library. That is, the example program with the _ugl.o ending.
结果还是出错了,无论是否设置extra_module为\target\lib\simpc\SIMNT\gnu\libwndml.a都不行
Errors while downloading C:/Tornado2.2/target/lib/objSIMNTgnuApps/ugldemo_ugl. _uglCommonClrCvt8888To565 _uglCommonClrCvt8888To888 _uglCommonClrCvt565To888 _uglCommonClrCvt565To8888 _uglCommonClrCvt888To565 _uglCommonClrCvt888To8888
2005-05-18 23:03:00     打赏
12楼
另外VxWorks工程中WindML组件配置的Link with WindML library组件无法包含,显示“this component is not installed” ,所以无法Include WindML in VxWorks image
如果包含WindML(complete 2D)组件配置则在编译时出现
partialImage. In function `usrRoot': c:\Tornado2.2\target\proj\Project1\default\c:\Tornado2.2\target\proj\Project1\prjConfig.c: 308: undefined reference to `uglCommonClrCvt8888To565' c:\Tornado2.2\target\proj\Project1\default\c:\Tornado2.2\target\proj\Project1\prjConfig.c: 308: undefined reference to `uglCommonClrCvt888To565' c:\Tornado2.2\target\proj\Project1\default\c:\Tornado2.2\target\proj\Project1\prjConfig.c: 308: undefined reference to `uglCommonClrCvt565To8888' c:\Tornado2.2\target\proj\Project1\default\c:\Tornado2.2\target\proj\Project1\prjConfig.c: 308: undefined reference to `uglCommonClrCvt888To8888' c:\Tornado2.2\target\proj\Project1\default\c:\Tornado2.2\target\proj\Project1\prjConfig.c: 308: undefined reference to `uglCommonClrCvt565To888' c:\Tornado2.2\target\proj\Project1\default\c:\Tornado2.2\target\proj\Project1\prjConfig.c: 308: undefined reference to `uglCommonClrCvt8888To888' c:\Tornado2.2\target\proj\Project1\default\c:\Tornado2.2\target\proj\Project1\prjConfig.c: 308: undefined reference to `uglCommonClrCvt888To8888' c:\Tornado2.2\target\proj\Project1\default\c:\Tornado2.2\target\proj\Project1\prjConfig.c: 308: undefined reference to `uglCommonClrCvt8888To888' c:\Tornado2.2\target\proj\Project1\default\c:\Tornado2.2\target\proj\Project1\prjConfig.c: 308: undefined reference to `uglCommonClrCvt888To8888' c:\Tornado2.2\target\proj\Project1\default\c:\Tornado2.2\target\proj\Project1\prjConfig.c: 308: undefined reference to `uglCommonClrCvt8888To888'
按照第2种方法 2. Dynamically download the WindML object module followed by the example program you desire to execute 也会出现 Errors while downloading C:/Tornado2.2/target/lib/simpc/SIMNT/gnu/wndml. _uglCommonClrCvt8888To565 _uglCommonClrCvt8888To888 _uglCommonClrCvt565To888 _uglCommonClrCvt565To8888 _uglCommonClrCvt888To565 _uglCommonClrCvt888To8888
2005-05-20 17:28:00     打赏
13楼
请教各位大侠我的如下步骤有什么问题么?
2.1 WindMl库配置编译 点击tools->WindML菜单命令,在出现的WindML Build对话框中选择WindML configuration 为simpc_RGB565_800x600.cfg,配置用于simnt的windml库,其配置缺省即可。 点击"Build"按钮生成二进制库target\lib\simpc\SIMNT\gnu\libwndml.a 2.2 更新VxWorks.exe 在simpc的基础上创建bootable工程。 工程中包含WindML组件配置 2.3 运行ugldemo 在前面的WindML库配置编译中,已生成应用例程的目标模块,位于"\target\lib\objSIMNTgnuApps"目录下。启动工程生成的vxworks.exe,如\target\proj\Project1\default\vxWorks.exe,下载位于"\target\lib\objSIMNTgnuApps"目录的ugldemo.o,在WindSh中使用ugldemo命令运行例程。 结果: 工程中包含WindML组件配置时不能包含Complete 2D否则会显示无法包含uglCommonClrCvt8888To565等 Errors while downloading C:/Tornado2.2/target/lib/objSIMNTgnuApps/ugldemo.o _uglCommonClrCvt8888To565 _uglCommonClrCvt8888To888 _uglCommonClrCvt565To888 _uglCommonClrCvt565To8888 _uglCommonClrCvt888To565 _uglCommonClrCvt888To8888 或者 Errors while downloading C:/Tornado2.2/target/lib/objSIMNTgnuApps/ugldemo_ugl.o _uglCommonClrCvt8888To565 _uglCommonClrCvt8888To888 _uglCommonClrCvt565To888 _uglCommonClrCvt565To8888 _uglCommonClrCvt888To565 _uglCommonClrCvt888To8888
2006-03-01 01:24:00     打赏
14楼
你这个问题解决了吗?
2006-04-11 04:34:00     打赏
15楼
我在3。0下只能运行两个例程,其他的例程运行出现异常
2012-08-18 20:45:08     打赏
16楼
您说的那个pdf去哪弄啊 能帮忙发一个么 谢谢 zxz000000000@163.com
2012-09-10 21:58:05     打赏
17楼
vxworks一直没有接触啊~!
共17条 2/2 ‹ 1 2 跳转至页
