谢谢两位。但运行的应该是工程所生成的vxworks.exe没错。我不知道怎么把WindML加进VxWorks内核。所以我选择的是下面的第三种方法,
To proceed with the tutorial, you may select one of the following: 1.Build a VxWorks image that includes the WindML object module. Using this technique, the VxWorks image includes all functionality so you can download and execute any WindML example program. 2. Dynamically download the WindML object module followed by the example program you desire to execute. 3. Dynamically download the example program pre-linked with the WindML library. That is, the example program with the _ugl.o ending.
结果还是出错了,无论是否设置extra_module为\target\lib\simpc\SIMNT\gnu\libwndml.a都不行
Errors while downloading C:/Tornado2.2/target/lib/objSIMNTgnuApps/ugldemo_ugl. _uglCommonClrCvt8888To565 _uglCommonClrCvt8888To888 _uglCommonClrCvt565To888 _uglCommonClrCvt565To8888 _uglCommonClrCvt888To565 _uglCommonClrCvt888To8888
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
