安装Rhapsody 后,安装目录下有个flexm文件夹,
安装盘提供liceense.dat,可是怎么用啊???
那位牛仁提供个截图啊?安装没问题,可就无法破解不能用啊,郁闷死啦。
0) with Host Details tool(it will be installed when you install the rhapsody), get hostname
1) Edit the license.dat and change <hostname> to your host name and then
put it to your x:\Rhapsody\flexlm dir.
2) Config & start the flexlm server.
This step is finished when you run lmtools in flexlm directory, configure the 'config services' tab add the path of your license file and lmgrd.exe file. then save.
3) Run the app
4) Done
