电子产品世界 » 论坛首页 » 行业应用 » 汽车电子 » 【S32K3XX】HSE随机数服务使用
【S32K3XX】HSE随机数服务使用
2025-12-21 20:45:58     打赏
【简介】
           我们之前介绍过S32K的HSE固件,该部分固件运行在S32K3芯片的M0上,固件中提供了多种服务,我们可以通过MU来和HSE core 来通讯调用对应的服务。HSE 内置了很多的服务,我们本次试验使用HSE 的随机数的服务来获取随机数。
HSE 的服务的使用可以参照S32K3xx_HSE_Service_API_Reference_Manual 文档,本次试验使用的TRNG 的sevice API接口如下:
对于接口的说明上面提到需要依赖 HSE_STATUS_RNG_INIT_OK 状态为1,该状态可以通过读取MU0 的FSR状态寄存器来获取,本地安装HSE 固件后状态为OK状态,意味着此时HSE 的随机数服务是可以正常使用的.
本地添加如下的代码来调用 HSE 的随机数服务:
 *   @file    hse_rng_test.c
 *   @brief   This file is used to verify Random number operations
 *   @details
 *   @addtogroup [SECURITY_FIRMWARE_UNITTEST]
 *   Project              : HSE 16FFC
 *   Platform             : Arm Architecture
 *   Peripheral           : CortexM7
 *   Dependencies         : none
 *   (c) Copyright 2018 NXP.
 *   This software is owned or controlled by NXP and may only be used strictly in accordance with
 *   the applicable license terms. By expressly accepting such terms or by downloading, installing,
 *   activating and/or otherwise using the software, you are agreeing that you have read, and that
 *   you agree to comply with and are bound by, such license terms. If you do not agree to
 *   be bound by the applicable license terms, then you may not retain, install, activate or
 *   otherwise use the software.
#ifdef __cplusplus
extern "C"
#endif
 *                                        INCLUDE FILES
#include "Mcal.h"
#include "hse_defs.h"
#include "Hse_Ip.h"
#include "hse_interface.h"
#include "string.h"
 *                          LOCAL TYPEDEFS (STRUCTURES, UNIONS, ENUMS)
 *                                       LOCAL MACROS
 *                                      LOCAL CONSTANTS
 *                                      LOCAL VARIABLES
static uint8_t muIf = 0U;
static uint8_t muChannelIdx = 1U;
 *                                      GLOBAL CONSTANTS
extern hseSrvDescriptor_t hseSrvDescriptor __attribute__((__section__(".mcal_bss_no_cacheable")));
 *                                      GLOBAL VARIABLES
 *                                   LOCAL FUNCTION PROTOTYPES
 *                                       LOCAL FUNCTIONS
 * Function:    GetRngNum
 * Description: This function is used to get random number.
 * Returns:
 * HSE_SRV_RSP_OK                        HSE service successfully executed with no error
 * HSE_SRV_RSP_INVALID_PARAM             The HSE request parameters are invalid (e.g
 *                                 misaligned, invalid range)
 * HSE_SRV_RSP_SMALL_BUFFER              The provided buffer is too small
 * HSE_SRV_RSP_NOT_ENOUGH_SPACE          There is no enough space to perform operation
 *                                 (e.g. load a key)
 * HSE_SRV_RSP_READ_FAILURE              The service request failed because read access
 *                                 was denied
 * HSE_SRV_RSP_WRITE_FAILURE             The service request failed because write access
 *                                 was denied
 * HSE_SRV_RSP_STREAMING_MODE_FAILURE    The service request that uses streaming mode
 *                                 failed (e.g. UPDATES and FINISH steps do not use
 *                                 the same HSE interface ID and channel ID as START step)
 * HSE_SRV_RSP_VERIFY_FAILED             HSE signals that a verification request fails (e.g.
 *                                 MAC and Signature verification)
 * HSE_SRV_RSP_KEY_NOT_AVAILABLE         This error code is returned if a key is locked due
 *                                 to failed boot measurement or an active debugger
 * HSE_SRV_RSP_KEY_INVALID               Specified key slot is either not valid or not available
 *                                 due to a key usage flags restrictions
 * HSE_SRV_RSP_KEY_EMPTY                 Specified key slot is empty
 * HSE_SRV_RSP_BUSY                      HSE request issued when the HSE is in busy state (on
 *                                 that HSE channel)
 * HSE_SRV_RSP_MEMORY_FAILURE            Detect physical errors, flipped bits etc., during
 *                                 memory read or write operations
 * HSE_SRV_RSP_GENERAL_ERROR             This error code is returned if an error not covered by
 *                                 the error codes above is detected inside HSE
hseSrvResponse_t GetRngNum(uint8_t *rngNum, uint32_t rngNumSize, hseRngClass_t rngClass)
    Hse_Ip_ReqType      HseIp_Request;
    hseSrvResponse_t hseStatus = HSE_SRV_RSP_GENERAL_ERROR;
    hseSrvDescriptor_t* pHseSrvDesc = &hseSrvDescriptor;
    hseGetRandomNumSrv_t* pGetRndSrv;
    memset(pHseSrvDesc, 0, sizeof(hseSrvDescriptor_t));
    pHseSrvDesc->srvId = HSE_SRV_ID_GET_RANDOM_NUM;
    pGetRndSrv = &(pHseSrvDesc->hseSrv.getRandomNumReq);
    pGetRndSrv->rngClass = rngClass;
    pGetRndSrv->pRandomNum = (HOST_ADDR)rngNum;
    pGetRndSrv->randomNumLength = rngNumSize;
    HseIp_Request.eReqType                  = HSE_IP_REQTYPE_SYNC;
    HseIp_Request.u32Timeout                = 0xFFFFFFFFUL;
    HseIp_Request.pCallbackParam            = NULL;
    HseIp_Request.pfCallback                = NULL;
    hseStatus = Hse_Ip_ServiceRequest(0, 1 , &HseIp_Request, pHseSrvDesc);
    return hseStatus;
 *                                       GLOBAL FUNCTIONS
 * Function:    GetRngDRG3Num
 * Description: This function is used to get random number of class DRG3.
 * Returns:
 *                                 (e.g. load a key)
 *                                 was denied
 *                                 was denied
 *                                 that HSE channel)
hseSrvResponse_t GetRngDRG3Num(uint8_t *rngNum, uint32_t rngNumSize)
    return GetRngNum(rngNum, rngNumSize, HSE_RNG_CLASS_DRG3);
 * Function:    GetRngDRG4Num
 * Description: This function is used to get random number of class DRG4.
 * Returns:
 *                                 (e.g. load a key)
 *                                 was denied
 *                                 was denied
 *                                 that HSE channel)
hseSrvResponse_t GetRngDRG4Num(uint8_t *rngNum, uint32_t rngNumSize)
    return GetRngNum(rngNum, rngNumSize, HSE_RNG_CLASS_DRG4);
 * Function:    GetRngPTG3Num
 * Returns:
 *                                 (e.g. load a key)
 *                                 was denied
 *                                 was denied
 *                                 that HSE channel)
hseSrvResponse_t GetRngPTG3Num(uint8_t *rngNum, uint32_t rngNumSize)
    return GetRngNum(rngNum, rngNumSize, HSE_RNG_CLASS_PTG3);
#ifdef __cplusplus
#endif
本地添加如下的测试代码调用,上述的hse 接口获取随机数:
        for(int i = 0;i < 100;i++)
            hseSrvResponse_t    hseSrvResponse = HSE_SRV_RSP_GENERAL_ERROR;
            hseSrvResponse = GetRngPTG3Num((uint8_t*)gTrng,8);
            if(hseSrvResponse != HSE_SRV_RSP_OK)
                printf("HSE GetRngPTG3Num failed %x .\r\n",(unsigned int)hseSrvResponse);
            else
                printf("HSE TRNG : 0x%08x 0x%08x\r\n",(unsigned int)gTrng[0],(unsigned int)gTrng[1]);
测试代码运行后已经按照预期的获取到了随机数。
关键词: S32K3学习整理
2025-12-24 09:48:59     打赏
这个输出数据的地址难道还是不定的吗?
