电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 【M5 STACK TAB5 W/O BATTERY】--WIFI扫描与STA连
【M5 STACK TAB5 W/O BATTERY】--WIFI扫描与STA连接
2026-01-05 23:54:32     打赏
      本篇讲述开发板WIFI扫描与STA连接功能。
一.代码准备
      开发板集成有ESP32-C6-MINI-1U芯片,支持WIFI6,故可WIFI 扫描链接。
  1. WIFI引脚宏定义
#define SDIO2_CLK GPIO_NUM_12
#define SDIO2_CMD GPIO_NUM_13
#define SDIO2_D0  GPIO_NUM_11
#define SDIO2_D1  GPIO_NUM_10
#define SDIO2_D2  GPIO_NUM_9
#define SDIO2_D3  GPIO_NUM_8
#define SDIO2_RST GPIO_NUM_15
2.设置串口波特率、字体,WIFI引脚配置
M5.begin();
Serial.begin(115200);
M5.Display.setFont(&fonts::FreeMonoBoldOblique24pt7b);
WiFi.setPins(SDIO2_CLK, SDIO2_CMD, SDIO2_D0, SDIO2_D1, SDIO2_D2, SDIO2_D3, SDIO2_RST);
3.WIFI STA连接,并显示屏显示
// STA MODE
WiFi.mode(WIFI_STA);
M5.Display.clear(GREEN);
M5.Display.println("WiFi mode set to STA");
WiFi.begin(ssid, password);
M5.Display.print("Connecting to ");
// Wait for connection
while (WiFi.status() != WL_CONNECTED) {
        delay(500);
        M5.Display.print(".");
M5.Display.println("");
M5.Display.print("Connected to ");
M5.Display.println(ssid);
M5.Display.print("IP address: ");
M5.Display.println(WiFi.localIP());
      连接画面如下:
4.延时并切换背景色,为WIFI扫描做准备
delay(3000);
    M5.Display.clear(GOLD);
    M5.Display.setFont(&fonts::FreeMonoBoldOblique9pt7b)
5.WIFI扫描
void loop()
    M5.Display.setCursor(0, 0);
    M5.Display.println("Scan start");
    // WiFi.scanNetworks will return the number of networks found.
    int n = WiFi.scanNetworks();
    M5.Display.println("Scan done");
    if (n == 0) {
        M5.Display.println("no networks found");
    } else {
        M5.Display.print(n);
        M5.Display.println(" networks found");
        M5.Display.println("Nr | SSID                             | RSSI | CH | Encryption");
        for (int i = 0; i < n; ++i) {
            // Print SSID and RSSI for each network found
            M5.Display.printf("%2d", i + 1);
            M5.Display.print(" | ");
            M5.Display.printf("%-32.32s", WiFi.SSID(i).c_str());
            M5.Display.printf("%4ld", WiFi.RSSI(i));
            M5.Display.printf("%2ld", WiFi.channel(i));
            switch (WiFi.encryptionType(i)) {
                case WIFI_AUTH_OPEN:
                    M5.Display.print("open");
                    break;
                case WIFI_AUTH_WEP:
                    M5.Display.print("WEP");
                    break;
                case WIFI_AUTH_WPA_PSK:
                    M5.Display.print("WPA");
                    break;
                case WIFI_AUTH_WPA2_PSK:
                    M5.Display.print("WPA2");
                    break;
                case WIFI_AUTH_WPA_WPA2_PSK:
                    M5.Display.print("WPA+WPA2");
                    break;
                case WIFI_AUTH_WPA2_ENTERPRISE:
                    M5.Display.print("WPA2-EAP");
                    break;
                case WIFI_AUTH_WPA3_PSK:
                    M5.Display.print("WPA3");
                    break;
                case WIFI_AUTH_WPA2_WPA3_PSK:
                    M5.Display.print("WPA2+WPA3");
                    break;
                case WIFI_AUTH_WAPI_PSK:
                    M5.Display.print("WAPI");
                    break;
                default:
                    M5.Display.print("unknown");
            M5.Display.println();
            delay(10);
    // Delete the scan result to free memory for code below.
    WiFi.scanDelete();
    // Wait a bit before scanning again.
    delay(5000);
      因为WIFI芯片支持2.4GHz WIFI,故扫描得到周边2.4GHzWIFI 热点信号,下图扫描可以看到,使用的WIFI热点HUAWEI-P信号强度最高。
6.全部工程代码如下
#include <Arduino.h>
#include <M5GFX.h>
#include <M5Unified.h>
#include <WiFi.h>
const char *ssid     = "HUAWEI-P";
const char *password = "pj_0915ll";
void setup()
    M5.begin();
    // If you select the M5Tab5 board in Arduino IDE, you could use the default pins defined.
    // WiFi.setPins(BOARD_SDIO_ESP_HOSTED_CLK, BOARD_SDIO_ESP_HOSTED_CMD, BOARD_SDIO_ESP_HOSTED_D0,
    //              BOARD_SDIO_ESP_HOSTED_D1, BOARD_SDIO_ESP_HOSTED_D2, BOARD_SDIO_ESP_HOSTED_D3,
    //              BOARD_SDIO_ESP_HOSTED_RESET);
    // STA MODE
        delay(500);
    delay(3000);
    M5.Display.setFont(&fonts::FreeMonoBoldOblique9pt7b);
    // AP MODE
    // WiFi.mode(WIFI_MODE_AP);
    // Serial.println("WiFi mode set to AP");
    // WiFi.softAP(ssid, password);
    // Serial.println("AP started");
    // Serial.print("IP address: ");
    // Serial.println(WiFi.softAPIP());
void loop()
    if (n == 0) {
    } else {
                    break;
                case WIFI_AUTH_WEP:
                    break;
                    break;
                    break;
                    break;
                    break;
                    break;
                    break;
                    break;
                default:
            delay(10);
    WiFi.scanDelete();
    delay(5000);
二.调试测验
      编译烧录后,可以看到连接到指定WIFI,且循环扫描到周围WIFI热点。
关键词: M5STACK     Tab5
