make xconfig的问题,安装完cygwin后一运行make xconfig就报错,到底什么问题呀,那位高手指点一下呀!
$ make xconfig
config/mkconfig > config.in
make -C /cygdrive/e/uClinux-44b0ii/config/scripts tkparse
make[1]: Entering directory `/cygdrive/e/uClinux-44b0ii/config/scripts'
make[1]: `tkparse' is up to date.
make[1]: Leaving directory `/cygdrive/e/uClinux-44b0ii/config/scripts'
ARCH=dummy /cygdrive/e/uClinux-44b0ii/config/scripts/tkparse < config.in >
confi
g.tmp
cat /cygdrive/e/uClinux-44b0ii/config/scripts/header.tk >> ./config.tk
cat config.tmp >> config.tk
rm -f config.tmp
echo "set defaults \"c:/.a9a8a\"" >> config.tk
echo "set help_file \"config/Configure.help\"" >> config.tk
cat /cygdrive/e/uClinux-44b0ii/config/scripts/tail.tk >> config.tk
chmod 755 config.tk
make: wish: Command not found
make: *** [xconfig] Error 127
关键词: xconfig 问题 安装 cygwin 运行 报
