我安装Rhapsody5。2以后,照着附带的Crack目录下的Crack.txt文件的说明,将licesence.dat拷贝到了Rhapsody/flexlm xia
可是Rhapsody还是不能打开(已经重启过),报错说license.dat错误。
crack.txt 文件是这样说的:
Launch Rhapsody. When the FlexLM License Finder appears, copy the LICENSE.DAT file from CRACK.ZIP to /RHAPSODY52/FLEXLM, overwriting the existing file. Use the FlexLM License Finder to browse to the license (select the local license option of course)。
请问:那个FlexLM License Finder怎么才能运行打开?
谢谢 !
