诚聘消费类芯片开发人才(年薪8万-30万)
The company is a worldwide leader in semiconductor solutions for broadband communications, enterprise networks and the digital home. it's innovative semiconductor system solutions enable global access networks, and are driving digital home information and entertainment networks worldwide. It's one of the top 10 company in this industry.
Software Engineer (STB)
Job Responsibilities:
Report to the Group Leader, and responsible for supporting the software applications of Set Top Box (STB) products.
Job Requirements
· University graduate with major in Computer Software or Electronic Engineering
· At least 2 years experience in Telecom, STB or Video development
· Good at programming using language C, Assemble and Make system
· Familiar with Real-time OS
· Experience in drivers development
· Knowledge in hardware, especially STB products
· Have experience on USB 2.0 stack, Host and Slave driver
· Good command of English
IC Implementation Team Leader
Reporting to the Design Engineering Manager and responsible for IC design, implementation, and leading the group.
Job Requirements:
· BSEE with 5+ years experience required (or MSEE with 3+ years experience)
· Gook knowledge of IC design flow & methodology
· Experience in working with .18um or finer technology
· Must be knowledgeable in large chip timing closure methodology, DFT structure planing & implementation
· Hands-on experience in synopsys design compiler/physical compiler/primetime is a must
· Knowledge of mentor DFT tools is a must
· Demonstrate Perl/Tcl/shell scripting skills
· Knowledge of backend tools (Jupiter/Astro) is a plus
· Good communication skills
· Good written & spoken English
FPGA Design Engineer
Responsible for prototyping large SoC chips using xilinx Virtex FPGA
Job Requirements:
· BSEE with 3+ years experience in complex FPGA design
· Must be knowledgeable of Xilinx Virtex FPGA architecture
· Verilog HDL proficiency required
· Experience in using NCSIM/Synplify/Xilinx ISE tools
· Hands-on experience in using laboratory's equipments, like logic analyzer & digital oscilloscopes
· Must be comfortable with unix environment
· Experience in using Certify & commercial ASIC prototyping system, like Hardi/Dini is a big plus
· Knowledge of frequency synthesis using Xilinx on-chip DCM is a plus.
· Good analytical & problem solving skills.
IC Design Engineer
System-on-chip logic design and verification. Reporting to the Group Leader, this position is responsible for unit level specification, micro architecture design, RTL coding/verification, synthesis and static timing analysis.
Job Requirements:
· BSEE with 5+ direct experience in ASIC design
· Must be proficient in verilog and C programming
· User level knowledge of unix/linux OS, familiar with Perl/TCL/Sh scripting is a plus
· Must be knowledgeable in one of the following areas
- MPEG2
- Digital video/audio processing
- USB/SATA/DDR or other high speed interface
- Familiar with ARM based SoC architecture
· Experience in designing multi-million set-top-box SoC is a big plus
· Good written and spoken English
· Good communication skills and able to work both independently and in a team
Hardware Component Engineer
Reporting to the Group Leader and responsible for components and equipments purchase. Build and maintain a hardware component library for PCB design and layout. Maintain the equipments daily. Contact with the components and equipments providers. Provide customer technical support.
Job Requirements:
University graduate with major in electronic, automatic control, telecommunication
Have more than 3 years relevant experience
Understand the analog and digital circuit design
Adroit in using EDA design software such as Protel, Orcad and PowerPCB
Strong ability on communication and purchase
TV system experience or RF circuit experience is needed
PCB Layout Engineer
Reporting to the Group Leader and responsible for design the PCB layout using EDA tools with optimization under design guidelines provided by engineers. High frequency digital circuit and video/audio analog circuit PCB design. Tracing the fabricating of the board and help to prepare the components for assembly. Provide customer technical support.
Job Requirements:
Master the high frequency analog and digital circuit design
RF circuit experience is important
Field Applications Engineer
Reporting to the Sales Manager, and responsible for achieving design-wins objectives to meet business revenue and growth goals, and providing technical support to customers.
Job Requirements:
· 5 yrs+ technical support in the semiconductor field or electronic product development experience with proven track record and strong interpersonal skills
· Analytical, aggressive, open-minded, optimistic and willing to learn
· Good English/Mandarin communication skills - both verbal and written
· Hands-on experience in DVB/IP set-top box, broadband communication products such as ethernet/DSL/cable modem and communication protocols, MPEG2/4 products, CA systems, MHPs, analog/digital video products
· Be able to manage and lead a team of technical professionals in meeting the company's design-win goals
· Good relationships with telcos, CATVs and STB/broadband OEMs a plus
Software Engineer (DSL)
· Specification, Design, Coding, Documentation, and Debugging/Testing of host code software for xDSL systems
· Coding responsibilities could include such functions as: initialization, application code download, diagnostic capabilities, advanced xDSL features, customer specific applications etc.
· Development mainly in ‘C’ language and in an embedded systems environment, e.g. VxWorks, pSoS, proprietary RTOS etc.
· Significant effort in DSL PHY debug and system-level problem isolation for customers
Job Requirements:
· Should have a technical degree BS or MS in one of the following: computer science, electrical engineering, electronics, or equivalent · Must have strong proficiency in ‘C’, assembly languages for RISC processors, and knowledge of embedded systems
· Must have good understanding of operating system concepts, embedded systems, real time systems and/or exposure to development of diagnostics software
· Must have good oral and written communication skills.
· Must be energetic, hard working, flexible, and a great team player
· Must be a problem solver, quick-to-learn, creative, self-motivated, and possess a desire to create new technology
· Ability to read, write and speak English.
DSP Firmware Engineer
Responsibilities:
· Implement signal processing algorithms on xDSL DSPs
· Work with hardware and software engineers to improve the performance of xDSL designs.
· Work with headquarters and customers to resolve physical layer related issues.
· Domestic and international travel required
Qualifications/Skills:
· MSEE or BSEE equivalent experience
· Theoretical knowledge of signal processing
· Knowledge of assembly language and DSP processors
· Strong organizational, analytical, and problem solving skills
· Excellent written/verbal communications skills in Chinese and English
· Experience with laboratory instruments (spectrum analyzer, oscilloscopes) is a plus
· Experience with DMT is a plus
System Software Engineer
Responsibilities:
· Design, development, documentation, and testing of software in ‘Systems On Chip’ (SOC) environment for:
· Initialization, bootstrapping using non-volatile memory, application code downloading and diagnostic tests
· Providing Kernel services like task scheduling, timer services, memory /buffer management, configuration management, etc.
· Must have good oral and written communication skills in English and Chinese
· Must have a good knowledge of xDSL communication protocols, PPPoE, PPPoA, Ethernet and ATM.
Interested parties can mail your full CV to helen.he@tophunter.com
关键词: 诚聘 消费类 芯片 开发 人才 年薪 -30万 e
