(DDS) A process by which you can digitally generate a frequency-agile,
highly-pure sinewave, or arbitrary waveform, from an
accurate reference clock. The digital output waveform is typically
tuned by a 32-bit digital word which allows sub-Hz frequency
agility. The DDS's frequency output is normally reconstructed
with a high-speed, high- performance D/A to generate an analog
output signal. The ability to add internal functions such as phase
modulation, amplitude modulation, digital filtering, and I&Q
outputs, are making DDS devices attractive for digital
communication applications. They serve in capacities such as
modulators, local oscillators, and clock detect/recovery circuits.
共1条
DDS
共1条
| OK1126B-S开发板下以导航按键控制云台/机械臂姿态调整被打赏¥29元 | |
| 【树莓派5】便携热成像仪被打赏¥36元 | |
| 【树莓派5】环境监测仪被打赏¥35元 | |
| OK1126B-S开发板下多时段语音提示型电子时钟被打赏¥27元 | |
| OK1126B-S开发板下函数构建及步进电机驱动控制被打赏¥25元 | |
| 【S32K3XX】LPI2C 参数配置说明被打赏¥20元 | |
| OK1126B-S开发板的脚本编程及应用设计被打赏¥27元 | |
| 5v升压8.4v两节锂电池充电芯片,针对同步和异步的IC测试被打赏¥35元 | |
| 【S32K3XX】S32DS LPI2C 配置失败问题解决被打赏¥22元 | |
| 【S32K3XX】FLASH 的 DID 保护机制被打赏¥19元 | |
