在redboot中加载自己用 ixp425 bsp 编译的bootrom.bin,加载成功,加载到了flash地址的0x50040000处,使用dump命令查看内容与bootrom.bin里一致,但是go的时候一直死机一样停着不动,为什么数据手册上说从0x30001000处运行,而不是从0x30000000处
下面是执行的过程,小弟新学,望各位大哥指教
RedBoot> fis list
Name FLASH addr Mem addr Length Entry point
Redboot 0x50000000 0x50000000 0x00040000 0x03000000
RedBoot config 0x50FC0000 0x50FC0000 0x00020000 0x00000000
FIS directory 0x50FE0000 0x50FE0000 0x00020000 0x00000000
RedBoot> load -r -v -b 0x03000000 bootrom.bin -h 192.168.0.16
Using default protocol (TFTP)
Raw file loaded 0x03000000-0x0305537f, assumed entry at 0x03000000
RedBoot> fis create bootrom -b 0x03000000 -f 0x50040000 -l 0x60000
... Erase from 0x50040000-0x500a0000: ...
... Program from 0x03000000-0x03060000 at 0x50040000: ...
... Unlock from 0x50fe0000-0x51000000: .
... Erase from 0x50fe0000-0x51000000: .
... Program from 0x03fdf000-0x03fff000 at 0x50fe0000: .
... Lock from 0x50fe0000-0x51000000: .
RedBoot> fis list
bootrom 0x50040000 0x03000000 0x00060000 0x03000000
RedBoot> fis load bootrom
RedBoot> go 0x03001000 -----------一直停在这里
