共3条
关于TMS320f2812的诡异问题
我使用的是CCS3。1
我在程序中使用两个static const 数组作为DFT运算的系数。可每次分配到具体的RAM中,数据都会改变。比如在程序中我定义:
static const int real[16] = {1024,946,724,392,0,-392,-724,-946,-1024,-946,-724,-392,0,392,724,946};
然后编译分配到Ram中后,查看memory中的数据,就会发现其中有数据变成0或者-65536。
请问这是什么原因?怎么解决呢?
已经试过的方法:
1,把数组定义为局部变量
2,使用CCS2。2
都不行。
谢谢各位!
关键词: 关于 TMS320f2812 诡异 问题
这是我的CMD文件。
MEMORY
PAGE 0 :
PRAMH0 : origin = 0x3f8000, length = 0x002000
PAGE 1 :
/* SARAM */
RAMM0 : origin = 0x000000, length = 0x000400
RAMM1 : origin = 0x000400, length = 0x000400
/* Peripheral Frame 0: */
DEV_EMU : origin = 0x000880, length = 0x000180
FLASH_REGS : origin = 0x000A80, length = 0x000060
CSM : origin = 0x000AE0, length = 0x000010
XINTF : origin = 0x000B20, length = 0x000020
CPU_TIMER0 : origin = 0x000C00, length = 0x000008
CPU_TIMER1 : origin = 0x000C08, length = 0x000008
CPU_TIMER2 : origin = 0x000C10, length = 0x000008
PIE_CTRL : origin = 0x000CE0, length = 0x000020
PIE_VECT : origin = 0x000D00, length = 0x000100
/* Peripheral Frame 1: */
ECAN_A : origin = 0x006000, length = 0x000100
ECAN_AMBOX : origin = 0x006100, length = 0x000100
/* Peripheral Frame 2: */
SYSTEM : origin = 0x007010, length = 0x000020
SPI_A : origin = 0x007040, length = 0x000010
SCI_A : origin = 0x007050, length = 0x000010
XINTRUPT : origin = 0x007070, length = 0x000010
GPIOMUX : origin = 0x0070C0, length = 0x000020
GPIODAT : origin = 0x0070E0, length = 0x000020
ADC : origin = 0x007100, length = 0x000020
EV_A : origin = 0x007400, length = 0x000040
EV_B : origin = 0x007500, length = 0x000040
SPI_B : origin = 0x007740, length = 0x000010
SCI_B : origin = 0x007750, length = 0x000010
MCBSP_A : origin = 0x007800, length = 0x000040
/* CSM Password Locations */
CSM_PWL : origin = 0x3F7FF8, length = 0x000008
/* SARAM */
/* DRAMH0 : origin = 0x009000, length = 0x001000
MYCONSTANT : origin = 0x008D40, length = 0x0002C0*/
DRAMH0 : origin = 0x008000, length = 0x002000
SECTIONS
/* Allocate program areas: */
.reset : > PRAMH0, PAGE = 0
.text : > PRAMH0, PAGE = 0
.cinit : > PRAMH0, PAGE = 0
/* Allocate data areas: */
.stack : > RAMM1, PAGE = 1
.bss : > DRAMH0, PAGE = 1
.ebss : > DRAMH0, PAGE = 1
.const : > DRAMH0, PAGE = 1
.econst : > DRAMH0, PAGE = 1
/* .econst : > MYCONSTANT, PAGE = 1*/
.sysmem : > DRAMH0, PAGE = 1
/* Allocate Peripheral Frame 0 Register Structures: */
DevEmuRegsFile : > DEV_EMU, PAGE = 1
FlashRegsFile : > FLASH_REGS, PAGE = 1
CsmRegsFile : > CSM, PAGE = 1
XintfRegsFile : > XINTF, PAGE = 1
CpuTimer0RegsFile : > CPU_TIMER0, PAGE = 1
CpuTimer1RegsFile : > CPU_TIMER1, PAGE = 1
CpuTimer2RegsFile : > CPU_TIMER2, PAGE = 1
PieCtrlRegsFile : > PIE_CTRL, PAGE = 1
PieVectTable : > PIE_VECT, PAGE = 1
/* Allocate Peripheral Frame 2 Register Structures: */
ECanaRegsFile : > ECAN_A, PAGE = 1
ECanaMboxesFile : > ECAN_AMBOX PAGE = 1
/* Allocate Peripheral Frame 1 Register Structures: */
SysCtrlRegsFile : > SYSTEM, PAGE = 1
SpiaRegsFile : > SPI_A, PAGE = 1
SciaRegsFile : > SCI_A, PAGE = 1
XIntruptRegsFile : > XINTRUPT, PAGE = 1
GpioMuxRegsFile : > GPIOMUX, PAGE = 1
GpioDataRegsFile : > GPIODAT PAGE = 1
AdcRegsFile : > ADC, PAGE = 1
EvaRegsFile : > EV_A, PAGE = 1
EvbRegsFile : > EV_B, PAGE = 1
ScibRegsFile : > SCI_B, PAGE = 1
McbspaRegsFile : > MCBSP_A, PAGE = 1
CsmPwlFile : > CSM_PWL, PAGE = 1
共3条
