电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » vxworks下目标机的启动
共6条 1/1 1 跳转至
vxworks下目标机的启动
2006-04-11 23:48:40     打赏
菜鸟向高手请教有关启动目标机方面的问题:(用的是intel(R)PRO/100 M Desktop Adapter网卡)
本人在启动目标机后,目标机屏幕前面部分的显示正常,后部分如下显示:
      Attached TCP/IP interface to fei unit0
Attaching network interface lo0...done
NFS client support not included.
VcWorks
copyright ...............
.........(此部分省略)
WDB ready.
在主机的wftpd上最后几行显示:
  [C 0017]04/04/06 16:15:08 command "Quit" received
[C 0017]04/04/06 16:15:08 QUIT or close - user TOM logged out
[! -001]04/04/06 16:15:08Received a command on socket 332 which I can't find
请高手指教一下出现"NFS client support not included"是什么意思?谢谢!
关键词: vxworks     目标机     启动
2006-04-14 18:43:00     打赏
那怎样去确定到底有没有?这对vxworks有何影响?
2006-04-15 06:48:00     打赏
Check you config.h or configAll.h, you will find whether you had included the NFS component. And you should know the function of NFS, you can add or delete as you wish.
2006-04-18 17:55:00     打赏
Thank you very much!I will have a try soon!
2006-04-20 22:46:00     打赏
请大侠帮忙:我的config.h和configAll.h中已经包含有NFS了.但还是有这问题,还请多指教!
2006-04-20 22:54:00     打赏
第一:你确定你需要用到NFS吗?
第二:你要用NFS,那你配置昊你的NFS Server了吗?如果没有,NFS还是会出现问题。
共6条 1/1 1 跳转至
站长统计
有奖问卷
英飞凌400V CoolSiC™重新定义高性能电源设计的功率密度和效率,含有奖小问卷,限前200名工程师!
