电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 深入浅出Linux设备驱动编程--定时器
2006-12-03 23:18:10     打赏
定时器 Linux内核中定义了一个timer_list结构,我们在驱动程序中可以利用之: struct timer_list { struct list_head list; unsigned long expires; //定时器到期时间 unsigned long data; //作为参数被传入定时器处理函数 void (*function)(unsigned long); }; 下面是关于timer的API函数: 增加定时器 void add_timer(struct timer_list * timer); 删除定时器 int del_timer(struct timer_list * timer); 修改定时器的expire int mod_timer(struct timer_list *timer, unsigned long expires); 使用定时器的一般流程为: (1)timer、编写function; (2)为timer的expires、data、function赋值; (3)调用add_timer将timer加入列表; (4)在定时器到期时,function被执行; (5)在程序中涉及timer控制的地方适当地调用del_timer、mod_timer删除timer或修改timer的expires。 我们可以参考drivers\char\keyboard.c中键盘的驱动中关于timer的部分: … #include <linux/timer.h> … static struct timer_list key_autorepeat_timer = { function: key_callback }; static void kbd_processkeycode(unsigned char keycode, char up_flag, int autorepeat) { char raw_mode = (kbd->kbdmode == VC_RAW); if (up_flag) { rep = 0; if(!test_and_clear_bit(keycode, key_down)) up_flag = kbd_unexpected_up(keycode); } else { rep = test_and_set_bit(keycode, key_down); /* If the keyboard autorepeated for us, ignore it. * We do our own autorepeat processing. */ if (rep && !autorepeat) return; } if (kbd_repeatkeycode == keycode || !up_flag || raw_mode) { kbd_repeatkeycode = -1; del_timer(&key_autorepeat_timer); } … /* * Calculate the next time when we have to do some autorepeat * processing. Note that we do not do autorepeat processing * while in raw mode but we do do autorepeat processing in * medium raw mode. */ if (!up_flag && !raw_mode) { kbd_repeatkeycode = keycode; if (vc_kbd_mode(kbd, VC_REPEAT)) { if (rep) key_autorepeat_timer.expires = jiffies + kbd_repeatinterval; else key_autorepeat_timer.expires = jiffies + kbd_repeattimeout; add_timer(&key_autorepeat_timer); } } … }
关键词: 深入浅出     Linux     设备驱动     编程     定时器     ti
