共1条
[灌水]DDK常用函数与数据结构描述
DDK常用函数与数据结构描述
Support Function and Data Structure Reference
ASSERT
ASSERTMSG
CM_FULL_RESOURCE_DESCRIPTOR
CM_PARTIAL_RESOURCE_DESCRIPTOR
CM_PARTIAL_RESOURCE_LIST
CM_RESOURCE_LIST
CONFIGURATION_INFORMATION
CONTAINING_RECORD
CONTROLLER_OBJECT
DbgBreakPoint
DbgPrint
DEVICE_DESCRIPTION
DEVICE_OBJECT
DriverEntry
DRIVER_OBJECT
ExAcquireFastMutex
ExAcquireFastMutexUnsafe
ExAcquireResourceExclusiveLite
ExAcquireResourceSharedLite
ExAcquireSharedStarveExclusive
ExAcquireSharedWaitForExclusive
ExAllocateFromNPagedLookasideList
ExAllocateFromPagedLookasideList
ExAllocatePool
ExAllocatePoolWithQuota
ExAllocatePoolWithQuotaTag
ExAllocatePoolWithTag
ExConvertExclusiveToSharedLite
ExDeleteNPagedLookasideList
ExDeletePagedLookasideList
ExDeleteResourceLite
ExFreePool
ExFreeToNPagedLookasideList
ExFreeToPagedLookasideList
ExGetCurrentResourceThread
ExInitializeFastMutex
ExInitializeNPagedLookasideList
ExInitializePagedLookasideList
ExInitializeResourceLite
ExInitializeWorkItem
ExInterlockedInsertHeadList
ExInterlockedInsertTailList
ExInterlockedRemoveHeadList
ExIsResourceAcquiredExclusiveLite
ExIsResourceAcquiredSharedLite
ExQueueWorkItem
ExReleaseFastMutex
ExReleaseFastMutexUnsafe
ExReleaseResourceForThreadLite
ExTryToAcquireFastMutex
ExTryToAcquireResourceExclusiveLite
HalAssignSlotResources
HalGetAdapter
HalGetBusData
HalGetBusDataByOffset
HalGetInterruptVector
HalSetBusData
HalSetBusDataByOffset
HalTranslateBusAddress
HKEY_LOCAL_MACHINE
InitializeListHead
InitializeObjectAttributes
InsertHeadList
InsertTailList
INTERFACE_TYPE
InterlockedDecrement
InterlockedExchange
InterlockedExchangeAdd
InterlockedIncrement
IoAcquireCancelSpinLock
IoAllocateAdapterChannel
IoAllocateController
IoAllocateErrorLogEntry
IoAllocateIrp
IoAllocateMdl
IoAssignResources
IoAttachDevice
IoAttachDeviceToDeviceStack
IoBuildAsynchronousFsdRequest
IoBuildDeviceIoControlRequest
IoBuildPartialMdl
IoBuildSynchronousFSDRequest
IoCallDriver
IoCancelIrp
IoCompleteRequest
IoConnectInterrupt
IoCopyCurrentIrpStackLocationToNext
IoCreateController
IoCreateDevice
IoCreateNotificationEvent
IoCreateSymbolicLink
IoCreateSynchronizationEvent
IoDeleteController
IoDeleteDevice
IoDeleteSymbolicLink
IoDetachDevice
IoDisconnectInterrupt
IO_ERROR_LOG_PACKET
IoFlushAdapterBuffers
IoFreeAdapterChannel
IoFreeController
IoFreeIrp
IoFreeMapRegisters
IoFreeMdl
IoGetConfiguationInformation
IoGetCurrentIrpStackLocation
IoGetCurrentProcess
IoGetDeviceObjectPointer
IoGetNextIrpStackLocation
IoInitializeDpcRequest
IoInitializeIrp
IoInitializeTimer
IoMakeAssociatedIrp
IoMapTransfer
IoMarkIrpPending
IoRegisterShutdownNotification
IoReleaseCancelSpinLock
IoRequestDpc
IO_RESOURCE_DESCRIPTOR
IO_RESOURCE_LIST
IO_RESOURCE_REQUIREMENTS_LIST
IoSetCancelRoutine
IoSetCompletionRoutine
IoSetNextIrpStackLocation
IoSizeOfIrp
IoSkipCurrentIrpStackLocation
IO_STACK_LOCATION
IoStartNextPacket
IoStartNextPacketByKey
IoStartPacket
IoStartTimer
IO_STATUS_BLOCK
IoStopTimer
IoUnregisterShutdownNotification
IoWriteErrorLogEntry
IsListEmpty
IRP
KdPrint
KeAcquireSpinLock
KeAcquireSpinLockAtDpcLevel
KeBugCheck
KeBugCheckEx
KeCancelTimer
KeClearEvent
KeDelayExecutionThread
KeDeregisterBugCheckCallback
KeFlushIoBuffers
KeGetCurrentIrql
KeGetCurrentProcessorNumber
KeGetDcacheFillSize
KeInitializeCallbackRecord
KeInitializeDeviceQueue
KeInitializeDpc
KeInitializeEvent
KeInitializeMutex
KeInitializeSemaphore
KeInitializeSpinLock
KeInitializeTimer
KeInitializeTimerEx
KeInsertByKeyDeviceQueue
KeInsertDeviceQueue
KeInsertQueueDpc
KeLowerIrql
KeNumberProcessors
KeQueryPerformanceCounter
KeQuerySystemTime
KeQueryTickCount
KeQueryTimeIncrement
KeRaiseIrql
KeReadStateEvent
KeReadStateMutex
KeReadStateSemaphore
KeReadStateTimer
KeRegisterBugCheckCallback
KeReleaseMutex
KeReleaseSemaphore
KeReleaseSpinLock
KeReleaseSpinLockFromDpcLevel
KeRemoveByKeyDeviceQueue
KeRemoveDeviceQueue
KeRemoveEntryDeviceQueue
KeRemoveQueueDpc
KeResetEvent
KeSetEvent
KeSetPriorityThread
KeSetTimer
KeSetTimerEx
KeStallExecutionProcessor
KeSynchronizeExecution
KeWaitForMultipleObjects
KeWaitForMutexObject
KeWaitForSingleObject
KEY_BASIC_INFORMATION
KEY_FULL_INFORMATION
KEY_NODE_INFORMATION
KEY_VALUE_BASIC_INFORMATION
KEY_VALUE_FULL_INFORMATION
KEY_VALUE_PARTIAL_INFORMATION
KIRQL
KSYNCHRONIZE_ROUTINE
LARGE_INTEGER
MmAllocateContiguousMemory
MmAllocateNonCachedMemory
MmCreateMdl
MmFreeContiguousMemory
MmFreeNonCachedMemory
MmGetMdlByteCount
MmGetMdlByteOffset
MmGetMdlVirtualAddress
MmGetPhysicalAddress
MmGetSystemAddressForMdl
MmInitializeMdl
MmIsAddressValid
MmMapIoSpace
MmMapLockedPages
MmPrepareMdlForReuse
MmProbeAndLockPages
MmQuerySystemSize
MmSizeOfMdl
MmUnlockPages
MmUnlockPagableImageSection
MmUnmapIoSpace
MmUnmapLockedPages
NTSTATUS
ObDereferenceObject
ObReferenceObjectByHandle
ObReferenceObjectByPointer
PCI_COMMON_CONFIG
PCI_SLOT_NUMBER
PDRIVER_CONTROL
PIO_DPC_ROUTINE
PIO_TIMER_ROUTINE
PKDEFERRED_ROUTINE
PKSTART_ROUTINE
PsCreateSystemThread
PsGetCurrentProcess
PsGetCurrentThread
PsTerminateSystemThread
READ_PORT_BUFFER_type
READ_PORT_type
READ_REGISTER_BUFFER_type
READ_REGISTER_type
RemoveEntryList
RemoveHeadList
RemoveTailList
RtlInitUnicodeString
RtlMoveMemory
RTL_QUERY_REGISTRY_ROUTINE
RTL_QUERY_REGISTRY_TABLE
RtlQueryRegistryValues
RtlUnicodeStringToAnsiString
RtlZeroMemory
UNICODE_STRING
_URB_CONTROL_DESCRIPTOR_REQUEST
_URB_HEADER
UsbBuildGetDescriptorRequest
WRITE_PORT_BUFFER_type
WRITE_PORT_type
WRITE_REGISTER_BUFFER_type
WRITE_REGISTER_type
ZwClose
ZwCreateFile
ZwCreateKey
ZwDeleteKey
ZwEnumerateKey
ZwEnumerateValueKey
ZwFlushKey
ZwMapViewOfSection
ZwOpenKey
ZwOpenSection
ZwQueryKey
ZwQueryValueKey
ZwSetInformationThread
ZwSetValueKey
ZwUnmapViewOfSection
关键词: 灌水 常用 函数 数据结构 描述
共1条
