共3条
stc89c58rd 请问stc89c58rd+,串口调试问题
问
我用的是stc89c58rd+,调试串口时,参考姚工的程序,功能是单片机向串口发送0123456789 ,接收中断函数返回相同的数,
现在的问题是程序运行后,每隔 一段时间串口调试窗口中就会出现一串“0123456789” 而不是单片机发送完“0123456789”后就等待接收中断。就好像单片机每个一段时间就在复位一次似的。 不知道是怎么回事。大家有遇到这样情况的吗?
程序如下:
此程序完全参考宏晶科技 姚永平 程序文件 ”定时器1作波特率发生器“
file:用汇编程序编写STC89c58RD+的串口调试程序
date:2006 07 07
created by:cyh
RELOAD_COUNT EQU 0FDH ; 11.0592MHZ 12T SMOD=0 9600BPS
;AUXR EQU 8EH
ORG 0000H
AJMP MAIN
ORG 0023H
AJMP UART_Interrupt
NOP
NOP
MAIN:
MOV SP, #7FH
ACALL Initial_UART
MOV R0, #30H
MOV R2,#10
LOOP:
MOV A,R0
ACALL Send_One_Byte
INC R0
DJNZ R2,LOOP
MAIN_WAIT:
SJMP MAIN_WAIT
UART_Interrupt:
JB RI, Is_UART_Receive
CLR TI
RETI
Is_UART_Receive:
CLR RI
PUSH ACC
MOV A, SBUF
ACALL Send_One_Byte
POP ACC
RETI
Initial_UART:
;SCON Bit 7 6 5 4 3 2 1 0
; SM0/FE SM1 SM2 REN TB8 RB8 TI RI
MOV SCON, #50H
MOV TMOD, #21H
MOV TH1, #RELOAD_COUNT
MOV TL1, #RELOAD_COUNT
;ANL AUXR, #10111111B ;12T MODE
SETB TR1
SETB ES
SETB EA
RET
Send_One_Byte:
CLR ES
CLR TI
MOV SBUF, A ;A=要发送的字节
Wait_Send_Finish:
JNB TI, Wait_Send_Finish
CLR TI
SETB ES
RET
答 1: 俺知道了知道了,是看门狗给复位了。呵呵 答 2: 恭喜,您已解决
程序如下:
date:2006 07 07
created by:cyh
;AUXR EQU 8EH
ORG 0000H
AJMP MAIN
ORG 0023H
AJMP UART_Interrupt
NOP
NOP
MAIN:
MOV SP, #7FH
ACALL Initial_UART
MOV R0, #30H
MOV R2,#10
LOOP:
MOV A,R0
ACALL Send_One_Byte
INC R0
DJNZ R2,LOOP
MAIN_WAIT:
SJMP MAIN_WAIT
UART_Interrupt:
CLR TI
RETI
Is_UART_Receive:
CLR RI
PUSH ACC
MOV A, SBUF
ACALL Send_One_Byte
POP ACC
RETI
Initial_UART:
MOV SCON, #50H
MOV TMOD, #21H
SETB TR1
SETB ES
SETB EA
RET
Send_One_Byte:
CLR ES
CLR TI
Wait_Send_Finish:
CLR TI
SETB ES
RET
共3条
