问
我在用2407A调试LCD的时候一老是不正确(有时候对)我单步执行看程序的时候就在,
for(i=100;i<480;i++)
for(j=100;j<800;j++)
x=i;
y=j;
ink=(unsigned long int )(x*0x0400)+y;
first=(unsigned int)((ink&0x070000)>>8)+(unsigned int)0x0aa;
second=((unsigned int )(ink&0xffff));
} 这里出问题,有时候可以进第2个for,有时候x,y的值乱变我把所有程序都贴出来,请大家帮我看看 答 1: c程序#include "f2407.h"
//#define first port1000
//#define second port1008
#define uchar unsigned char
//#define fore 0x011
//#define back 0x044
ioport unsigned port0ffff;
ioport unsigned port1000;
ioport unsigned port1008;
void inline disable()
asm( " setc INTM ");
void inline enable()
asm(" clrc INTM ");
main()
unsigned long int ink;
unsigned int x,y=0;
//unsigned char x,y ;
uchar i,j;
//disable();
asm(" clrc INTM ");
asm( " clrc SXM ");
asm( " clrc OVM ");
asm( " clrc CNF ");
*SCSR1=0X86FE;
*WDCR=0X0E8;
*IMR=0X0000;
*IFR=0X0FFFF;
*MCRA=*MCRA&0X00FF;
*PBDATDIR=(*PBDATDIR|0X0FfFF)&0X0FF0f;
*PBDATDIR=(*PBDATDIR|0X0FfFF)&0X0FF00;
*PBDATDIR=(*PBDATDIR|0X0FfFF)&0X0FF04;
*MCRC=*MCRC&0X0FFE1;
*PEDATDIR=*PEDATDIR|0X0FF00;
//*PEDATDIR=0X0FF02;
//while(1);
x=0;
//y=0;
x=i;
y=j;
while(1);
//KEY INT PROCEDURE
void interrupt key()
int k;
disable();
// START();
enable();
void interrupt nothing()
int i;
i=0;
return;
} 答 2: CMD文件-stack 512
MEMORY
PAGE 0: /* Program Memory */
VECS: org=00000h, len=00040h /* internal FLASH */
FLASH: org=0100h, len=07F00h /* internal FLASH */
//EXTPROG: org=08800h, len=07000h /* external SRAM */
PAGE 1: /* Data Memory */
B2: org=00060h, len=00020h /* internal DARAM */
B0: org=00200h, len=00100h /* internal DARAM */
B1: org=00300h, len=00100h /* internal DARAM */
SARAM: org=00800h, len=00800h /* internal SARAM */
EXTDATA: org=08000h, len=08000h /* external SRAM */
SECTIONS
/* Sections generated by the C-compiler */
.text: > FLASH PAGE 0 /* initialized */
.cinit: > FLASH PAGE 0 /* initialized */
.const: > FLASH PAGE 0 /* initialized */
.switch: > FLASH PAGE 0 /* initialized */
.bss: > EXTDATA PAGE 1 /* uninitialized */
.stack: > SARAM PAGE 1 /* uninitialized */
.sysmem: > B1 PAGE 1 /* uninitialized */
/* Sections declared by the user */
vectors: > VECS PAGE 0 /* initialized */
答 3: 还有在写I/O口的时候在写I/O口的时候也是有时候对(用示波器看)我怀疑是CCS,还是CMD有问题?只要X,Y(I,J)值是对的,LCD也就正常 答 4: 还有一个问题有时候程序改一点点(比如变量初值)都会使程序跳不高主程序(方针的时候)
我是初学的请大家帮帮忙 答 5: 个人见解首先把对端口IO的操作改为对内部RAM的操作,软件跟踪几次 确保数据的无误性 否则先修改之
其次 加长你的IO口访问周期,以达到LCD的访问时序要求. 答 6: 你好zgl7903,你QQ是多少我还问你问题 答 7: 个人见解不好意思,我个人对2407并不熟悉,我只是提醒你一种方法,具体问题还得你老兄自己努力。 答 8: uchar i,j;uchar i,j;
你的uchar是几位的,如果是8位会出问题 答 9: 不是不是8位是16位的 答 10: 请大家帮忙看看,谢谢 答 11: 怎么?怎么? 答 12: 好了重新找了个计算机,没有问题了郁闷
x=i;
y=j;
asm(" clrc INTM ");
main()
unsigned int x,y=0;
uchar i,j;
//disable();
asm(" clrc INTM ");
asm( " clrc SXM ");
asm( " clrc OVM ");
asm( " clrc CNF ");
*SCSR1=0X86FE;
*WDCR=0X0E8;
*IMR=0X0000;
*IFR=0X0FFFF;
*MCRA=*MCRA&0X00FF;
//while(1);
x=0;
//y=0;
x=i;
y=j;
while(1);
//KEY INT PROCEDURE
int k;
disable();
// START();
enable();
int i;
i=0;
return;
MEMORY
SECTIONS
| 【FreeRtos】FreeRtos + MPU模块的配置使用被打赏¥32元 | |
| 【分享开发笔记,赚取电动螺丝刀】墨水屏文本显示器被打赏¥25元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX软件读取HTS221温湿度被打赏¥22元 | |
| M5PAPERESP32EINKDEVKIT评测|使用MicroPython开发M5Paper被打赏¥15元 | |
| OK1126B-S开发板下以导航按键控制云台/机械臂姿态调整被打赏¥29元 | |
| 【树莓派5】便携热成像仪被打赏¥36元 | |
| 【树莓派5】环境监测仪被打赏¥35元 | |
| OK1126B-S开发板下多时段语音提示型电子时钟被打赏¥27元 | |
| OK1126B-S开发板下函数构建及步进电机驱动控制被打赏¥25元 | |
| 【S32K3XX】LPI2C 参数配置说明被打赏¥20元 | |
