共3条
uClinux-20030305 for ARM7-S3C4510 patch.
找了点时间,为uClinux-dist-200305做了个patch,针对开发板的,也适用于SNDS100.
1. 解决了使用16Mbyte RAM的问题
2. 增加了一个 2Mbyte RAM Disk ? ->/ramdisk
usage:
cp dailzh.patch /home/uClinux-dist
patch -p1 < dailzh.patch
chmod 777 mkuclinux
./mkuclinux(一堆命令的组合)
这个版本的boa可以使用,下载image.ram以后,可以用浏览器访问http://192.168.168.101.
有个问题就是tftp,我只向 /ramdisk成功地下载了一次,然后就再也不能用了,总报错。
哪位有时间把这个问题解决了请贴出来。
关键词: uClinux-20030305 ARM7-S3C
uClinux-dist-20030522启动信息:
Linux version 2.4.20-uc0 (root@dailzh) (gcc version 2.95.3
20010315 (release)(ColdFire patches - 20010318 from http://fiddes.net/coldfire/)
(uClinux XIP and shared lib patches from http://www.snapgear.com/)) #1 一 5月 19
23:44:11 CST 2003
Processor: Samsung S3C4510B revision 6
Architecture: SNDS100
On node 0 totalpages: 4096
zone(0): 0 pages.
zone(1): 4096 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/rom0
Calibrating delay loop... 49.76 BogoMIPS
Memory: 16MB = 16MB total
Memory: 14636KB available (1321K code, 163K data, 40K init)
Dentry cache hash table entries: 2048 (order: 2, 16384 bytes)
Inode cache hash table entries: 1024 (order: 1, 8192 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Samsung S3C4510 Serial driver version 0.9 (2001-12-27) with no serial options en
abled
ttyS00 at 0x3ffd000 (irq = 5) is a S3C4510B
ttyS01 at 0x3ffe000 (irq = 7) is a S3C4510B
Blkmem copyright 1998,1999 D. Jeff Dionne
Blkmem copyright 1998 Kenneth Albanowski
Blkmem 1 disk images:
0: BE4B8-15C4B7 [VIRTUAL BE4B8-15C4B7] (RO)
RAMDISK driver initialized: 16 RAM disks of 1024K size 1024 blocksize
Samsung S3C4510 Ethernet driver version 0.1 (2002-02-20)
eth0: 00:40:95:36:35:34
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 1024)
VFS: Mounted root (romfs filesystem) readonly.
Freeing init memory: 40K
Shell invoked to run file: /etc/rc
Command: hostname Samsung
Command: /bin/expand /etc/ramfs.img /dev/ram0
Command: /bin/expand /etc/ramfs2048.img /dev/ram1
Command: mount -t proc proc /proc
Command: mount -t ext2 /dev/ram0 /var
Command: mount -t ext2 /dev/ram1 /ramdisk
Command: chmod 777 /ramdisk
Command: mkdir /var/config
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: ifconfig lo 127.0.0.1
Command: route add -net 127.0.0.0 netmask 255.255.255.0 lo
Command: ifconfig eth0 192.168.168.101 netmask 255.255.255.0 up
Command: cat /etc/motd
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/ \
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/
Patch for ARM7-S3C4510 from http://www.dailzh.com/
Execution Finished, Exiting
Sash command shell (version 1.1.1)
共3条
| PCF8574功能模块及其使用被打赏¥20元 | |
| LPS25HB气压传感器及其检测被打赏¥18元 | |
| HTS221温湿度传感器及其检测被打赏¥18元 | |
