共7条
开发板的bootloader代码!
bootloader启动信息:(19200,8,n,1)
This program is base on the BIOS, patched by www.dailzh.com
uClinux Loader for SAMSUNG S3C4510B v1.0
1 - Flash Write(Now can't work)
2 - Load uClinux
Please Select(only 2 is enabled): 2
Mini TFTP Server 1.0 (IP : 192.168.168.101) - Load uClinux image(RAM)
Command: tftpcmd 192.168.168.101 69 put image.ramStarting the TFTP download...
Boot uClinux? (y/n) y
共7条
