电子产品世界 » 论坛首页 » 活动中心 » 有奖活动 » 机器视觉
机器视觉
2026-04-07 07:39:04     打赏
test_server_huakuang.zip
import asyncio
import websockets
import cv2
import numpy as np
import logging
import sys  # 补全sys导入(解决NameError)
from ultralytics import YOLO  # YOLOv8 核心库
# ===== 核心配置 =====
HOST = "0.0.0.0"
PORT = 8081
# 全局变量:存储最新帧(加锁避免异步冲突)
latest_frame = None
frame_lock = asyncio.Lock()
# 加载 YOLO 模型(第一次运行自动下载轻量版模型)
model = YOLO("yolov8n.pt")  # n=轻量版,s=标准版,m=中版,l=大版
# 配置日志(方便调试)
logging.basicConfig(level=logging.INFO)
logger = logging.getLogger("esp32_camera_server")
async def handle_camera(websocket):
    """处理ESP32摄像头连接(兼容旧版WebSocket客户端)"""
    global latest_frame
    logger.info("✅ ESP32摄像头客户端已连接!")
    try:
        while True:
            try:
                # 接收ESP32发送的JPEG二进制数据(设置超时避免卡死)
                data = await asyncio.wait_for(websocket.recv(), timeout=30.0)
                # 转换为OpenCV帧(容错处理)
                if isinstance(data, bytes) and len(data) > 0:
                    nparr = np.frombuffer(data, np.uint8)
                    frame = cv2.imdecode(nparr, cv2.IMREAD_COLOR)
                    # 加锁更新最新帧
                    async with frame_lock:
                        latest_frame = frame
            except asyncio.TimeoutError:
                # 超时无数据,继续等待(不断开连接)
                continue
            except websockets.exceptions.ConnectionClosed:
                logger.info("
