电子产品世界 » 论坛首页 » 活动中心 » 合作大赛 » 有这个头文件vmgfxold.h,老是报错!!!
共9条 1/1 1 跳转至页
2010-12-01 16:07:55     打赏
如果有这个的话 #include "vmgfxold.h",比如官方给的demo中的socket以及gps_demo中,出现如下错
Compiling...
socket.c
k:\microsoft visual studio\vre ide\include\vmgfxold.h(1) : error C2018: unknown character '0xff'
k:\microsoft visual studio\vre ide\include\vmgfxold.h(1) : error C2018: unknown character '0xfe'
k:\microsoft visual studio\vre ide\include\vmgfxold.h(1) : error C2014: preprocessor command must start as first nonwhite space
k:\microsoft visual studio\vre ide\include\vmgfxold.h(114) : fatal error C1020: unexpected #endif
Error executing cl.exe.
WHY?啊
关键词: 有这     个头     文件     vmgfxold.h     老是     报错
2010-12-01 17:53:50     打赏
难道这个头文件vmgfxold.h有问题哦....
   并且在别人电脑上,也会出一样的问题..........
2010-12-01 18:55:10     打赏
这个头文件中的内容难道有错了么? 一些为那个vmgfxold.h中的内容. #ifndef VMCPT_H_ #define VMCPT_H_ /************************************************************************ * The graphic interfaces are changed a lot after VRE1.2.5, therefore the * applications based on the interfaces of older VRE should use this file * and re-complie for new VRE platform. The file, vmgraph.h, supports the * development for new platform. ************************************************************************/ #ifdef __cplusplus extern "C" { #endif #include "vmsys.h" #include "vmgraph.h" #include "vmlog.h" /* vmgraph.h*/ void vm_graphic_lock(void); void vm_graphic_unlock(void); VMUINT8 * vm_graphic_get_buffer(void); void vm_graphic_flush_buffer(void); void vm_initialize_screen_buffer(void); void vm_finalize_screen_buffer(void); VMINT vm_graphic_draw_gif(VMUINT8* gif, VMINT gif_len, VMINT x, VMINT y, VMINT width, VMINT height, VMINT frame_index); VMINT vm_graphic_bitblt(VMINT resid, int x, int y); void vm_graphic_drawtext(VMINT x, VMINT y, VMWSTR s, VMINT32 length, VMINT color); void vm_graphic_setpixel(VMINT x, VMINT y, VMINT color); void vm_graphic_drawline(VMINT x0, VMINT y0, VMINT x1, VMINT y1, VMINT color); void vm_graphic_drawrect(VMINT x, VMINT y, VMINT width, VMINT height, VMINT color); void vm_graphic_fillrect(VMINT x, VMINT y, int width, int height, int color); #define vm_graphic_set_text_clip vm_graphic_set_clip #define vm_graphic_reset_text_clip vm_graphic_reset_clip /* vmddraw.h*/ void vm_dd_initialize_clip_rect(void); void vm_dd_set_clip(VMINT x, VMINT y, VMINT width, VMINT height); void vm_dd_reset_clip(void); void vm_dd_blt_all_cutting_frames(VMBYTE *buf, VMBYTE *source_surface, VMINT x_num, VMINT y_num, VMINT width, VMINT height); void vm_dd_img_flood(VMBYTE *buf, VMINT x_dst, VMINT y_dst,VMBYTE *source_surface, VMINT width, VMINT height, VMINT frame_index); void vm_dd_copy(VMBYTE *buf, VMINT x_dest, VMINT y_dest, VMBYTE *source_surface, VMINT x_src, VMINT y_src, VMINT width, VMINT height, VMINT frame_index, VMINT direction); void vm_dd_flood_4_regional(VMBYTE *buf, VMINT x_dst, VMINT y_dst,VMBYTE *source_surface, VMINT width, VMINT height, VMINT frame_index); VMUINT8* vm_dd_load_image(VMUINT8 *img, VMINT img_len); struct frame_prop * vm_dd_get_img_property(VMUINT8 *img, VMUINT8 frame_index); VMINT vm_dd_get_frame_number(VMUINT8 *img); void vm_dd_clean(VMUINT8* buf, VMUINT16 color16); void vm_dd_active_layer(VMINT handle); #define vm_dd_clean_ex vm_dd_clean #define vm_dd_copy_ex vm_dd_copy #define vm_dd_setpixel_ex vm_graphic_set_pixel #define vm_dd_setpixel vm_graphic_set_pixel #define vm_dd_getpixel_ex vm_graphic_get_pixel #define vm_dd_getpixel vm_graphic_get_pixel #define vm_dd_line_ex vm_graphic_line #define vm_dd_line vm_graphic_line #define vm_dd_rect_ex vm_graphic_rect #define vm_dd_rect vm_graphic_rect #define vm_dd_fillrect_ex vm_graphic_fill_rect #define vm_dd_fillrect vm_graphic_fill_rect #define vm_dd_blt_ex vm_graphic_blt #define vm_dd_blt vm_graphic_blt #define vm_dd_rotate_ex vm_graphic_rotate #define vm_dd_rotate vm_graphic_rotate #define vm_dd_mirror_ex vm_graphic_mirror #define vm_dd_mirror vm_graphic_mirror #define vm_dd_blt_with_opacity vm_graphic_blt_ex /* vmdraw.h*/ #define vm_graph_initialize vm_initialize_screen_buffer #define vm_graph_finalize vm_finalize_screen_buffer #define vm_graph_get_buffer vm_graphic_get_buffer #define vm_graph_flush_buffer vm_graphic_flush_buffer #define vm_graph_initialize_clip_rect vm_dd_initialize_clip_rect #define vm_graph_blt_all_cutting_frames vm_dd_blt_all_cutting_frames #define vm_graph_img_flood vm_dd_img_flood #define vm_graph_copy vm_dd_copy #define vm_graph_load_image vm_dd_load_image #define vm_graph_get_img_property vm_dd_get_img_property #define vm_graph_get_frame_number vm_dd_get_frame_number #define vm_graph_clean vm_dd_clean #define vm_graph_get_bits_per_pixel vm_graphic_get_bits_per_pixel #define vm_graph_set_clip vm_graphic_reset_clip #define vm_graph_reset_clip vm_graphic_reset_clip #define vm_graph_get_screen_width vm_graphic_get_screen_width #define vm_graph_get_screen_height vm_graphic_get_screen_height #define vm_graph_get_character_height vm_graphic_get_character_height #define vm_graph_get_character_width vm_graphic_get_character_width #define vm_graph_measure_character vm_graphic_measure_character #define vm_graph_get_string_width vm_graphic_get_string_width #define vm_graph_set_font vm_graphic_set_font #define vm_graph_setpixel vm_graphic_set_pixel #define vm_graph_getpixel vm_graphic_get_pixel #define vm_graph_line vm_graphic_line #define vm_graph_rect vm_graphic_rect #define vm_graph_fillrect vm_graphic_fill_rect #define vm_graph_blt vm_graphic_blt #define vm_graph_rotate vm_graphic_rotate #define vm_graph_mirror vm_graphic_mirror #define vm_graph_draw_gif vm_graphic_draw_gif void vm_graph_drawtext(VMINT x, VMINT y, VMWSTR s, VMINT32 length, VMUINT16 color); void vm_graph_release_surface(VMUINT8 * off_surface); VMUINT8 * vm_graph_create_custom_buf(VMINT width, VMINT height); void vm_graph_delete_custom_buf(VMUINT8 * custom_buf); void vm_graph_move(VMBYTE *screen_buf, VMINT x_dest, VMINT y_dest, VMBYTE *custom_buf, VMINT x_src, VMINT y_src, VMINT width, VMINT height); #ifdef __cplusplus } #endif #endif
2010-12-02 09:10:30     打赏
unexpected #endif
是不是头文件里的预编译没有匹配好呀?
2010-12-02 21:16:23     打赏
您好,
   请您开启vmgfxold.h文件,编辑後(加个空白)另存一般文本的格式, 应该就可以编译通过了
2010-12-03 12:47:54     打赏
那个文件 是 UTF-8 编码的,要转成 ANSI
2010-12-06 10:25:10     打赏
7楼
同学您有研究过喔。是的,
只要文件编码成ANSI,另存新档就可以编译了!
2010-12-10 13:25:06     打赏
8楼
新旧版的sdk关于vmgfxold这个头文件不一样,旧版的能通过,新版的不行。 这样会影响作品评比么
2010-12-10 15:47:05     打赏
9楼
您好
    不会影响
    您只要提交完整工程的压缩包(含代码)
    大会可以帮您重编译即可!
共9条 1/1 1 跳转至页
