电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Coherent Sampling vs. Window Sampling
2012-04-16 21:16:45     打赏
关键词: coherent sampling, window sampling, high-speed, data converters, analog-to-digital, analogue-to-digital, A to D, A/D, converters, ADCs
Abstract: One of the most useful techniques for evaluating the dynamic performance of fast and ultra-fast data converters is coherent sampling. This technique increases the spectral resolution of a Fast Fourier Transform (FFT) and eliminates the need for window sampling when certain conditions are met. However, if the conditions for coherent sampling cannot be met, window sampling can be used. The following application note compares coherent sampling with window sampling and provides an explanation of how to evaluate high-speed analog-to-digital converters (ADCs) using either method, while detailing the advantages and disadvantages of each.
 Coherent Sampling vs. Window Sampling.pdf
关键词: Coherent     Sampling     Window
