电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » ntroduction to Computed Tomography (CT)
ntroduction to Computed Tomography (CT) Medical Imaging
2012-04-16 21:34:57     打赏
关键词: computed tomography, ct, medical image, medical components, catscan, cat scan, ct scan
Abstract: This tutorial explains how computed tomography (CT) imaging systems generate 3-D images of internal body structures. The high-end spiral CT technique is explained, as is the method by which light collected from photodiodes is processed into an electrical signal and eventually converted to a digital format by a digital acquisition system (DAS). This conversion process must happen quickly, which makes ADC sampling speeds and resolutions critical for CT designs.
 Introduction to Computed Tomography (CT) Medical Imaging.pdf
关键词: ntroduction     Computed     Tomo
