电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » ysjabcd的功放DIY进程贴(更新 更新红外遥控功能)
共12条 2/2 ‹ 1 2 跳转至页
2015-04-25 17:50:07     打赏
11楼
借用了论坛里给出的模块,先把按键调通了,为了方便大家看,没用模块化编程,都在一个大程序里,直接贴上来了。
#include<reg52.h>
#include<intrins.h>
#define UINT8 unsigned char
sbit LED = P1^5;   //指示灯
sbit IR_INT0 = P3^2;     //红外
//调音按键
sbit KEY_SUB = P1^2;
sbit KEY_ADD = P1^3;
sbit KEY_MUTE = P1^1;
sbit CHECK = P1^0; //检测音频线有没有接入
sbit MUTE = P1^4;     //功放静音
  //MCU调音量
sbit CLOCK = P3^3;
sbit UPDOWN = P3^6;
//还有几个全局变量,主要是存功放和按键状态的
unsigned char uup=0;    //有连续按键时用
unsigned char IRtimer;//
unsigned char phonejack = 1;//    //有没有音频线状态
unsigned char MUTEstate = 0;    //MUTE状态
void Delay1ms() //@11.0592MHz
unsigned char i, j;
_nop_();
_nop_();
_nop_();
i = 11;
j = 190;
do
while (--j);
} while (--i);
//控制音量加
void Volume_add(void)
    UINT8 iadd = 5;
    UPDOWN = 1;
    while(--iadd)
        Delay1ms();
    CLOCK = 0;
    iadd = 5;
    while(--iadd)
        Delay1ms();
    CLOCK = 1;
// 控制音量减
  void Volume_sub(void)
    UINT8 isub = 5;
      UPDOWN = 0;
      while(--isub)
        Delay1ms();
      CLOCK = 0;
      isub = 5;
      while(--isub)
        Delay1ms();
      CLOCK = 1;
void flash_LED(UINT8 a)
LED = 0;
while(a--)
{ Delay1ms(); }
LED = 1;
//关于按键,软件上一定要做延时处理
//下面是给大家一个延时的方法,高手请略过;
void Scan_key(void)
    int loop;
    if(KEY_SUB == 0)
        {LED = 1;
            loop = 10;
            while((KEY_SUB == 0) && (loop >0))
                {--loop;Delay1ms();}
            if(KEY_SUB == 0)
                    Volume_sub();
               //     u_sstr("-1\n\r");
                  flash_LED(20);
                    loop = 1500;
            while(KEY_SUB == 0)
                    Volume_sub();
                    flash_LED(20);;
                    loop = 200;
    if(KEY_ADD == 0)
        {LED = 1;
        loop = 10;
        while((KEY_ADD == 0) && (loop >0))
        if(KEY_ADD == 0)
                Volume_add();
              //  u_sstr("+1\n\r");
                flash_LED(20);
                loop = 1500;
        while(KEY_ADD == 0)
                Volume_add();
                flash_LED(20);
                loop = 200;
        if(KEY_MUTE == 0)
            LED = 1;
            loop = 10;
            while((KEY_MUTE == 0) && (loop >0))
             if(KEY_MUTE == 0)
                 if(MUTEstate == 1)
                    MUTEstate = 0;
//                    MUTE = 0;
                 //  u_sstr("MUTE\n\r");
                  else
                    MUTEstate = 1;
 //                   MUTE = 1;
                  //  u_sstr("CLOSE MUTE\n\r");
                flash_LED(20);
            while(KEY_MUTE==0);
void checkphone(void)
    if(CHECK == 0)  //没有耳机插入
                MUTE = 1;
                phonejack = 0;  //没有耳机
   else    //有耳机
  if(phonejack == 0)
                   flash_LED(20);
  phonejack = 1;
            if(MUTEstate == 1)
                    MUTE = 1;
            else
                    MUTE = 0;
void main()
while(1)
checkphone();
Scan_key();
2015-05-15 19:20:19     打赏
12楼
实现了遥控控制音量大小、静音等功能
源代码仍然延续之前的方式添加。
#include<reg52.h>
#include<intrins.h>
//调音按键
  //MCU调音量
sbit CLOCK = P3^3;
sbit UPDOWN = P3^6;
UINT8 IRCOM[7];//红外数组
unsigned char i, j;
_nop_();
_nop_();
_nop_();
i = 11;
j = 190;
do
while (--j);
} while (--i);
//控制音量加
    UINT8 iadd = 5;
    UPDOWN = 1;
    while(--iadd)
        Delay1ms();
    CLOCK = 0;
    iadd = 5;
    while(--iadd)
        Delay1ms();
    CLOCK = 1;
// 控制音量减
    UINT8 isub = 5;
      UPDOWN = 0;
      while(--isub)
        Delay1ms();
      CLOCK = 0;
      isub = 5;
      while(--isub)
        Delay1ms();
      CLOCK = 1;
LED = 0;
while(a--)
{ Delay1ms(); }
LED = 1;
//关于按键,软件上一定要做延时处理
void Scan_key(void)
    int loop;
    if(KEY_SUB == 0)
        {LED = 1;
            loop = 10;
            if(KEY_SUB == 0)
                    Volume_sub();
                  flash_LED(20);
                    loop = 1500;
            while(KEY_SUB == 0)
                    Volume_sub();
                    flash_LED(20);;
                    loop = 200;
    if(KEY_ADD == 0)
        {LED = 1;
        loop = 10;
        if(KEY_ADD == 0)
                Volume_add();
                flash_LED(20);
                loop = 1500;
        while(KEY_ADD == 0)
                Volume_add();
                flash_LED(20);
                loop = 200;
        if(KEY_MUTE == 0)
            LED = 1;
            loop = 10;
             if(KEY_MUTE == 0)
                 if(MUTEstate == 1)
                    MUTEstate = 0;
//                    MUTE = 0;
                  else
                    MUTEstate = 1;
 //                   MUTE = 1;
                flash_LED(20);
            while(KEY_MUTE==0);
                MUTE = 1;
   else    //有耳机
  if(phonejack == 0)
                   flash_LED(20);
  phonejack = 1;
            if(MUTEstate == 1)
                    MUTE = 1;
            else
                    MUTE = 0;
void init()
EA=1;    //开总中断
EX0=1; //开外部中断0
IT0=0;               //外部中断1设为低电平触发
void delayhw(unsigned char x)    //x*0.14MS 红外延时 此延时适于11.0592,STC15系列单片机,如换单片机,需改延时。
unsigned char i, j;
i = 2;
j = 126;
do
while (--j);
} while (--i);
void main()
init();
while(1)
checkphone();
Scan_key();
void exter0() interrupt 0
     unsigned char j,k,N=0;
     EX0 = 0;
// delayhw(15);
if (IR_INT0==1)
     { EX0 =1;
  return;
while (!IR_INT0)   //确认IR信号出现   //等IR变为高电平,跳过9ms的前导低电平信号。
    {delayhw(1);}
for (j=0;j<4;j++)         //收集四组数据
for (k=0;k<8;k++)        //每组数据有8位
  while (IR_INT0)            //等 IR 变为低电平,跳过4.5ms的前导高电平信号。
  {delayhw(1);}
  while (!IR_INT0)          //等 IR 变为高电平
  {delayhw(1);}
  while (IR_INT0)           //计算IR高电平时长
   delayhw(1);
   N++;
   if (N>=30)
{ EX0=1;
 return;}                  //0.14ms计数过长自动离开。
   }                       //高电平计数完毕
   IRCOM[j]=IRCOM[j] >> 1;                  //数据最高位补“0”
   if (N>=8) {IRCOM[j] = IRCOM[j] | 0x80;}  //数据最高位补“1”
   N=0;
   if (IRCOM[2]!=~IRCOM[3])
   { EX0=0;
     return; }
if(IRCOM[2]==0x19)
flash_LED(20);
Volume_add();
if(IRCOM[2]==0x16)
flash_LED(20);
Volume_sub();
if(IRCOM[2]==0x47)
flash_LED(20);
MUTEstate = !MUTEstate;
     EX0 = 1;
return;
共12条 2/2 ‹ 1 2 跳转至页
