电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » triangle
triangle
2018-01-24 13:28:51     打赏
Given a triangle, find the minimum path sum from top to bottom. Each step you may move to adjacent numbers on the row below.
For example, given the following triangle
     [2],
    [3,4],
   [6,5,7],
  [4,1,8,3]
The minimum path sum from top to bottom is11(i.e., 2 + 3 + 5 + 1 = 11).
Note:
Bonus point if you are able to do this using only O(n) extra space, where n is the total number of rows in the triangle.
题意:给定一个三角形,找到一条从顶部到底部的路径,要求路径上的和的值最小,每一步你只能往下一行的相邻位置走下去;这种典型的利用动态规划方式思考的;设f(i,j)是从第一行到第i行,第j个数字的最小和值,那么f(i,j)要么是f(i-1, j-1) 而来,要么是f(i-1, j)而来,因此最优子结构为f(i,j)=min(f(i-1, j-1), f(i-1, j))+triangle[i][j]
通过这种方式,可以得到从第一行到第n行的所有点的最小和值,然后
取第n行的最小值即可[cpp] view plain copy
  1. class Solution
  2. {
  3. public:
  4.     int minimumTotal(vector<vector<int>> & triangle)
  5.     {
  6.         if (triangle.size()==0)
  7.         {
  8.             return 0;
  9.         }
  10.
  11.         vector<vector<int>> dp;
  12.         vector<int> vec;
  13.         vec.push_back(triangle[0][0]);
  14.
  15.         dp.push_back(vec);
  16.         vec.resize(0);
  17.
  18.         for (int i=1; i<triangle.size(); i++)
  19.         {
  20.             for (int j=0; j<triangle[i].size(); j++)
  21.             {
  22.                 if (j==0)
  23.                 {
  24.                     vec.push_back(triangle[i][0]);
  25.                 }
  26.                 else if(j==triangle[i].size()-1)
  27.                 {
  28.                     vec.push_back(triangle[i][j]+dp[i-1][j-1]);
  29.                 }
  30.                 else
  31.                 {
  32.                     vec.push_back(min(dp[i - 1][j - 1] + triangle[i][j], dp[i - 1][j] + triangle[i][j]));
  33.                 }
  34.             }
  35.
  36.             dp.push_back(vec);
  37.             vec.resize(0);
  38.         }
  39.
  40.         int last = dp.size() - 1;
  41.         int minpath = dp[last][0];
  42.         for (int i = 1; i<dp[last].size(); i++)
  43.             if (dp[last][i]<minpath)
  44.                 minpath = dp[last][i];
  45.
  46.         return minpath;
  47.     }
  48. };
