电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » word-ladder
word-ladder
2018-01-26 13:08:08     打赏
Given two words (start and end), and a dictionary, find the length of shortest transformation sequence from start to end, such that:
  1. Only one letter can be changed at a time
  2. Each intermediate word must exist in the dictionary
For example,
Given:
start ="hit"
end ="cog"
dict =["hot","dot","dog","lot","log"]
As one shortest transformation is"hit" -> "hot" -> "dot" -> "dog" -> "cog",
return its length5.
Note:
  • Return 0 if there is no such transformation sequence.
  • All words have the same length.
  • All words contain only lowercase alphabetic characters.
题意:将单词一通过给定的词典中进行转换,返回转换次数最少,转换成end单词;
思路:使用广度优先遍历;1、将start放入队列q1,初始count=0;2、当q1非空,逐个遍历q1中的单词,count++;3、设q1中的单词为str, 寻找其临近单词s,如果s等于end返回count+1否则,将s放入队列q2中,4、将q1和 q2 交换,继续执行2
[cpp] view plain copy
  1. class Solution
  2. {
  3.     int ladderLength(string start, string end, unorder_set<string>& dict)
  4.     {
  5.         queue<string> q1, q2, *p1, *p2;
  6.
  7.         int count = 0;
  8.         for (p1=&q1, p2=&q2, p1->push(start); p1->size(); swap(p1, p2))
  9.         {
  10.             ++count;
  11.             for (string str; p1->size(); p1->pop())
  12.             {
  13.                 str = p1->front();
  14.                 for (int i=0; i<str.length(); i++)
  15.                 {
  16.                     string s = str;
  17.                     for (char ch = 'a'; ch <= 'z'; ++ch)
  18.                     {
  19.                         if (ch==str[i])
  20.                         {
  21.                             continue;
  22.                         }
  23.                         s[i] = ch;
  24.                         if (s==end)
  25.                         {
  26.                             return count + 1;
  27.                         }
  28.
  29.                         if (dict.find(s)!=dict.end())
  30.                         {
  31.                             p2->push(s);
  32.                             dict.erase(s);
  33.                         }
  34.                     }
  35.                 }
  36.             }
  37.         }
  38.         return 0;
  39.     }
  40. };
