电子产品世界 » 论坛首页 » 嵌入式开发 » 国产MCU » 【昉·星光2RISC-V单板计算机】物体识别的板端推理
2025-05-20 14:16:57     打赏
【昉·星光 2 RISC-V单板计算机】物体识别的板端推理
本文介绍了昉·星光2 (StarFive2)单板计算机基于 OpenCV 模型实现物体识别的板端推理。
准备工作
在实现前面帖子描述的官方软件库更新、OpenCV正常调用的基础上,进一步实现 python 代码改进,实现物体识别的板端推理的项目设计。
新建文件夹
SSH 登录系统,进入 home/user/ 文件夹,为了便于管理项目,新建 Ai_Inf 文件夹用以装载对应的板端识别工程文件,包括 onnx 模型文件、coco.names 物体类别文件、yolov5_inf.py 执行程序以及待识别的目标输入图片文件等。
流程图
项目代码
新建 yolov5_inf.py 文件,添加板端推理代码。
import cv2
import numpy as np
import argparse
import sys
# Constants
INPUT_WIDTH = 640       # Model input width
INPUT_HEIGHT = 640      # Model input height
SCORE_THRESHOLD = 0.5   # Class score threshold
NMS_THRESHOLD = 0.45    # Non-Maximum Suppression threshold
CONFIDENCE_THRESHOLD = 0.45  # Confidence threshold
# Text parameters
FONT_FACE = cv2.FONT_HERSHEY_SIMPLEX  # Font type
FONT_SCALE = 0.7       # Font scale factor
THICKNESS = 1          # Font thickness
# Colors (BGR format)
BLACK = (0, 0, 0)      # Black
BLUE = (255, 178, 50)  # Blue
GREEN = (0, 255, 0)    # Green
YELLOW = (0, 255, 255) # Yellow
RED = (0, 0, 255)      # Red
def draw_label(input_image, label, left, top):
    """Draw detection label on image
    # Get text size
    text_size = cv2.getTextSize(label, FONT_FACE, FONT_SCALE, THICKNESS)
    dim, baseline = text_size[0], text_size[1]
    # Draw black background rectangle
    cv2.rectangle(input_image, (left, top),
                 (left + dim[0], top + dim[1] + baseline),
                 BLACK, cv2.FILLED)
    # Draw text on rectangle
    cv2.putText(input_image, label, (left, top + dim[1]),
               FONT_FACE, FONT_SCALE, YELLOW, THICKNESS, cv2.LINE_AA)
def pre_process(input_image, net):
    """Image preprocessing function
    # Create 4D blob (1,3,640,640)
    blob = cv2.dnn.blobFromImage(
        input_image,
        1/255,                   # Scale factor
        (INPUT_WIDTH, INPUT_HEIGHT),  # Target size
        [0,0,0],                 # Mean subtraction
        swapRB=True,             # BGR to RGB
        crop=False               # No cropping
    # Set model input
    net.setInput(blob)
    # Forward pass to get output
    outputs = net.forward(net.getUnconnectedOutLayersNames())
    return outputs
def post_process(input_image, outputs, classes):
    """Post-processing: Parse detection results and draw bounding boxes
    class_ids = []
    confidences = []
    boxes = []
    # Get number of detections
    rows = outputs[0].shape[1]
    image_height, image_width = input_image.shape[:2]
    # Resizing factors
    x_factor = image_width / INPUT_WIDTH
    y_factor = image_height / INPUT_HEIGHT
    # Parse detections
    for r in range(rows):
        row = outputs[0][0][r]
        confidence = row[4]
        # Filter weak detections
        if confidence >= CONFIDENCE_THRESHOLD:
            classes_scores = row[5:]
            class_id = np.argmax(classes_scores)
            # Filter by class score threshold
            if classes_scores[class_id] > SCORE_THRESHOLD:
                confidences.append(confidence)
                class_ids.append(class_id)
                # Get bounding box coordinates
                cx, cy, w, h = row[0], row[1], row[2], row[3]
                left = int((cx - w/2) * x_factor)
                top = int((cy - h/2) * y_factor)
                width = int(w * x_factor)
                height = int(h * y_factor)
                boxes.append([left, top, width, height])
    # Apply Non-Maximum Suppression
    indices = cv2.dnn.NMSBoxes(boxes, confidences, CONFIDENCE_THRESHOLD, NMS_THRESHOLD)
    result_image = input_image.copy()
    # Draw filtered detections
    for i in indices:
        box = boxes[i]
        left, top, width, height = box
        cv2.rectangle(result_image, (left, top), (left + width, top + height),
                     GREEN, 2*THICKNESS)
        label = f"{classes[class_ids[i]]}: {confidences[i]:.2f}"
        draw_label(result_image, label, left, top)
    return result_image
def main():
    # Parse arguments
    parser = argparse.ArgumentParser(description='YOLOv5 Object Detection')
    parser.add_argument('image_path', type=str, default="model/test.jpg", help='Input image path')
    parser.add_argument('--model', type=str, default="model/yolov5n.onnx", help='ONNX model path')
    parser.add_argument('--classes', type=str, default="model/coco.names", help='Class names file path')
    parser.add_argument('--output', type=str, default="result.jpg", help='Output image path')
    args = parser.parse_args()
    # Load class names
    try:
        with open(args.classes, 'rt') as f:
            classes = f.read().rstrip('\n').split('\n')
    except Exception as e:
        print(f"Error: Cannot load class file {args.classes}: {str(e)}")
        sys.exit(1)
    # Load model
    try:
        net = cv2.dnn.readNet(args.model)
        net.setPreferableBackend(cv2.dnn.DNN_BACKEND_OPENCV)
        net.setPreferableTarget(cv2.dnn.DNN_TARGET_CPU)  # Use CPU on VisionFive 2
        print(f"Error: Cannot load model {args.model}: {str(e)}")
        sys.exit(1)
    # Read input image
    try:
        frame = cv2.imread(args.image_path)
        if frame is None:
            raise ValueError("Cannot read image file")
        print(f"Error: Cannot load image {args.image_path}: {str(e)}")
        sys.exit(1)
    # Run inference pipeline
    try:
        detections = pre_process(frame, net)
        result_img = post_process(frame.copy(), detections, classes)
        # Calculate inference time
        t, _ = net.getPerfProfile()
        inference_time = t * 1000.0 / cv2.getTickFrequency()
        print(f"Inference time: {inference_time:.2f} ms")
        # label on image
        time_label = f'Inference time: {inference_time:.2f} ms'
        cv2.putText(result_img, time_label, (20, 30), FONT_FACE, FONT_SCALE, RED, THICKNESS, cv2.LINE_AA)
        # Save result
        cv2.imwrite(args.output, result_img)
        print(f"Results have saved to: {args.output}")
        print(f"Error in the inference process: {str(e)}")
        sys.exit(1)
    sys.exit(0)
if __name__ == '__main__':
    main()
保存代码至板端,注意 ONNX 和 coco.names 文件的位置,修改代码中模型文件对应的路径。
运行程序
进入执行文件所在文件夹,输入指令
python3 yolov5_inf.py model/test.jpg
运行程序,推理结束后,在执行程序同目录下生成 result.jpg 文件,即推理结果。
仅使用 CPU 完成推理过程,耗时较长,单张图片的实际推理时间大约 5 秒 .
识别效果
针对 YOLOv5 模型可识别的项目(见 coco.names ),选取了一些特定场景进行物体识别,并展示板端推理的结果。
数码电器
马克杯没有识别出来,可能原因是模型未收录,或图片清晰度不足、拍摄角度问题等。
识别洗衣机存在误差,且部分电器未能识别,原因可能是模型未收录。
水果蔬菜
识别效果较好,基本可以正确识别,但置信度有待提升。
可见,对于多种物体混合分布的情况,识别效果会收到影响。
车辆行人
对于真实场景(街道、路口)的识别较为仔细和丰富,且结果准确率较高。
重复识别同一或相似场景,可以得到较为一致的推理结果和准确率。
对于国外的素材场景能够实现更佳的推理结果,模型需要增加本土环境的训练。
动物
对于动物的识别存在误差,准确率在 60% 左右,建议增加训练样本数量和种类,以覆盖更多物种。
运动
运动场景也是推理识别常见的应用场合,试验结果表明该模型对运动素材具有较好的识别能力。
识别范围
由 coco.names 可知该模型支持识别的物品种类包括
person
bicycle
car
motorbike
aeroplane
bus
train
truck
boat
traffic light
fire hydrant
stop sign
parking meter
bench
bird
cat
dog
horse
sheep
cow
elephant
bear
zebra
giraffe
backpack
umbrella
handbag
tie
suitcase
frisbee
skis
snowboard
sports ball
kite
baseball bat
baseball glove
skateboard
surfboard
tennis racket
bottle
wine glass
cup
fork
knife
spoon
bowl
banana
apple
sandwich
orange
broccoli
carrot
hot dog
pizza
donut
cake
chair
sofa
pottedplant
bed
diningtable
toilet
tvmonitor
laptop
mouse
remote
keyboard
cell phone
microwave
oven
toaster
sink
refrigerator
book
clock
vase
scissors
teddy bear
hair drier
toothbrush
共包含 80 种物体类别,基本覆盖日常生活场景。
总结
本文介绍了昉·星光2 (StarFive2)单板计算机基于 OpenCV 模型实现物体识别的板端推理,包括准备工作、流程图、项目代码、程序运行等流程,并展示了不同应用场景下的识别效果,为该设备在人工智能方面和边缘 AI 的应用与开发提供了参考。
关键词: RISC-V     推理     模型     识别     VisionFiv
