电子产品世界 » 论坛首页 » 行业应用 » 汽车电子 » 【EasyLogger】裸机环境适配
共4条 1/1 1 跳转至
【EasyLogger】裸机环境适配
2026-02-23 12:37:27   被打赏 50 分(兑奖)     打赏
【简介】
            Easy logger 是个轻量级的日志库,详细的介绍可以通过GitHub 的链接查看( https://github.com/armink/EasyLogger )。从github 获取的 Easy Logger 的源文件的目录结构还是很清晰的顶层目录的文件如下。
移植适配相对也很容易,移植适配的流程可以参照此链接的说明(https://github.com/armink/EasyLogger/blob/master/docs/zh/port/kernel.md
按照适配说明文档将源代码加入到工程中编译。
   将Easylogger 的头文件路径加入到工程中。
源文件加入工程后按照移植适配的文档适配port 接口,本地使用的no_os 的裸机的方式,按照demo 路径下的 EasyLogger\demo\non_os\stm32f10x\components\easylogger\port\elog_port.c 文件的接口适配Easy Logger 依赖的接口。
对应接口实现如下:
 * This file is part of the EasyLogger Library.
 * Copyright (c) 2015, Armink, <armink.ztl@gmail.com>
 * Permission is hereby granted, free of charge, to any person obtaining
 * a copy of this software and associated documentation files (the
 * 'Software'), to deal in the Software without restriction, including
 * without limitation the rights to use, copy, modify, merge, publish,
 * distribute, sublicense, and/or sell copies of the Software, and to
 * permit persons to whom the Software is furnished to do so, subject to
 * the following conditions:
 * The above copyright notice and this permission notice shall be
 * included in all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED 'AS IS', WITHOUT WARRANTY OF ANY KIND,
 * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
 * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
 * IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
 * CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
 * TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
 * SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
 * Function: Portable interface for S32K3 platform.
 * Created on: 2015-04-28
#include "elog.h"
#include <stdio.h>
#if defined (CPU_S32K324)
#include "S32K324_COMMON.h"
#elif defined (CPU_S32K312)
#include "S32K312_COMMON.h"
#else
#error "Need add S32K3XX_COMMON.h"
#endif
#include "core_cm7.h"
#if defined (CFG_EASY_LOGGER_TERMINAL_UART)
#include "Lpuart_Uart_Ip.h"
#endif
 * EasyLogger port initialize
 * @return result
ElogErrCode elog_port_init(void) {
ElogErrCode result = ELOG_NO_ERR;
return result;
 * EasyLogger port deinitialize
void elog_port_deinit(void) {
/* add your code here */
 * output log port interface
 * @param log output of log
 * @param size log size
void elog_port_output(const char *log, size_t size) {
for(unsigned int i = 0; i < size; i++)
while((CFG_EASY_LOGGER_TERMINAL_UART->STAT & LPUART_STAT_TC_MASK)>>LPUART_STAT_TC_SHIFT==0);
CFG_EASY_LOGGER_TERMINAL_UART->DATA = log[i];
#else
/* output to terminal */
printf("%.*s", size, log);
#endif
//TODO output to flash
 * output lock
void elog_port_output_lock(void) {
__disable_irq();
 * output unlock
void elog_port_output_unlock(void) {
__enable_irq();
 * get current time interface
 * @return current time
const char *elog_port_get_time(void) {
return "10:08:12";
 * get current process name interface
 * @return current process name
const char *elog_port_get_p_info(void) {
return "pid:1008";
 * get current thread name interface
 * @return current thread name
const char *elog_port_get_t_info(void) {
return "tid:24";
依赖的接口适配完成后添加如下的配置文件elog_cfg.h
 * Copyright (c) 2015-2016, Armink, <armink.ztl@gmail.com>
 * Function: It is the configure head file for this library.
 * Created on: 2015-07-30
#ifndef _ELOG_CFG_H_
#define _ELOG_CFG_H_
/* enable log output. default open this macro */
#define ELOG_OUTPUT_ENABLE
/* setting static output log level */
#define ELOG_OUTPUT_LVL                      ELOG_LVL_VERBOSE
/* enable assert check */
#define ELOG_ASSERT_ENABLE
/* buffer size for every line's log */
#define ELOG_LINE_BUF_SIZE                   256
/* output line number max length */
#define ELOG_LINE_NUM_MAX_LEN                5
/* output filter's tag max length */
#define ELOG_FILTER_TAG_MAX_LEN              16
/* output filter's keyword max length */
#define ELOG_FILTER_KW_MAX_LEN               16
/* output filter's tag level max num */
#define ELOG_FILTER_TAG_LVL_MAX_NUM          5
/* output newline sign */
#define ELOG_NEWLINE_SIGN                    "\r\n"
/* enable log color */
#define ELOG_COLOR_ENABLE
/* change the some level logs to not default color if you want */
#define ELOG_COLOR_ASSERT                        (F_MAGENTA B_NULL S_NORMAL)
#define ELOG_COLOR_ERROR                         (F_RED B_NULL S_NORMAL)
#define ELOG_COLOR_WARN                          (F_YELLOW B_NULL S_NORMAL)
#define ELOG_COLOR_INFO                          (F_CYAN B_NULL S_NORMAL)
#define ELOG_COLOR_DEBUG                         (F_GREEN B_NULL S_NORMAL)
#define ELOG_COLOR_VERBOSE                       (F_BLUE B_NULL S_NORMAL)
/* enable log fmt */
/* comment it if you don't want to output them at all */
#define ELOG_FMT_USING_FUNC
#define ELOG_FMT_USING_DIR
#define ELOG_FMT_USING_LINE
#endif /* _ELOG_CFG_H_ */
适配配置完成后添加如下的测试代码来验证Easy Logger 的功能。
 * Copyright (c) 2015-2017, Armink, <armink.ztl@gmail.com>
 * Function: windows demo.
#define LOG_TAG    "main"
#include <elog.h>
#include <stdio.h>
#include <stdlib.h>
static void test_elog(void);
int main(void) {
    /* initialize EasyLogger */
    elog_init();
    /* set EasyLogger log format */
    elog_set_fmt(ELOG_LVL_ASSERT, ELOG_FMT_ALL);
    elog_set_fmt(ELOG_LVL_ERROR, ELOG_FMT_LVL | ELOG_FMT_TAG | ELOG_FMT_TIME);
    elog_set_fmt(ELOG_LVL_WARN, ELOG_FMT_LVL | ELOG_FMT_TAG | ELOG_FMT_TIME);
    elog_set_fmt(ELOG_LVL_INFO, ELOG_FMT_LVL | ELOG_FMT_TAG | ELOG_FMT_TIME);
    elog_set_fmt(ELOG_LVL_DEBUG, ELOG_FMT_ALL & ~ELOG_FMT_FUNC);
    elog_set_fmt(ELOG_LVL_VERBOSE, ELOG_FMT_ALL & ~ELOG_FMT_FUNC);
    /* start EasyLogger */
    elog_start();
    /* dynamic set enable or disable for output logs (true or false) */
//    elog_set_output_enabled(false);
    /* dynamic set output logs's level (from ELOG_LVL_ASSERT to ELOG_LVL_VERBOSE) */
//    elog_set_filter_lvl(ELOG_LVL_WARN);
    /* dynamic set output logs's filter for tag */
//    elog_set_filter_tag("main");
    /* dynamic set output logs's filter for keyword */
//    elog_set_filter_kw("Hello");
    /* dynamic set output logs's tag filter */
//    elog_set_filter_tag_lvl("main", ELOG_LVL_WARN);
    /* test logger output */
    test_elog();
    return EXIT_SUCCESS;
 * EasyLogger demo
void test_elog(void) {
    while(true) {
        /* test log output for all level */
        log_a("Hello EasyLogger!");
        log_e("Hello EasyLogger!");
        log_w("Hello EasyLogger!");
        log_i("Hello EasyLogger!");
        log_d("Hello EasyLogger!");
        log_v("Hello EasyLogger!");
上述代码运行后Easy Logger 的输出日志按照配进行输出,运行结果如下:
2026-02-28 16:04:35     打赏
它的这个颜色突出显示,是terminal实现的,还是EasyLogger实现的?
2026-02-28 16:11:03     打赏
那不感兴趣了。
添加颜色转义字符会降低数据的有效载荷
2026-03-02 17:28:37     打赏
我现在使用的串口工具具有这个“着色”功能。
所以,我只需要添加 error标识符即可。
共4条 1/1 1 跳转至
