电子产品世界 » 论坛首页 » 活动中心 » 有奖活动 » AG32VH407下多种显示屏的显示驱动
共5条 1/1 1 跳转至
2026-04-07 19:43:51     打赏
为增强表现力和丰富显示内容,给AG32VH407开发板配置一款SPI接口TFT屏是十分必要的显示屏的分辨率为320*240像素点。
TFT显示屏与开发板的连接关系为:
SCLK----PIN_62
SDIN----PIN_61
RST----PIN_59
DC ----PIN_58
CS ----PIN_57
为此VE文件中建立的映射关系为:
GPIO5_0 PIN_62
GPIO5_1 PIN_61
GPIO5_2 PIN_59
GPIO5_3 PIN_58
GPIO5_4 PIN_57
为便于向TFT显示屏提供高低电平,所作的语句定义为:
#define LCD_SCLK_Set   GPIO_SetHigh(GPIO5,GPIO_BIT0)
#define LCD_SCLK_Clr   GPIO_SetLow(GPIO5,GPIO_BIT0)
#define LCD_SDIN_Set   GPIO_SetHigh(GPIO5,GPIO_BIT1)
#define LCD_SDIN_Clr   GPIO_SetLow(GPIO5,GPIO_BIT1)
#define LCD_RST_Set    GPIO_SetHigh(GPIO5,GPIO_BIT2)
#define LCD_RST_Clr    GPIO_SetLow(GPIO5,GPIO_BIT2)
#define LCD_DC_Set     GPIO_SetHigh(GPIO5,GPIO_BIT3)
#define LCD_DC_Clr     GPIO_SetLow(GPIO5,GPIO_BIT3)
#define LCD_CS_Set     GPIO_SetHigh(GPIO5,GPIO_BIT4)
#define LCD_CS_Clr     GPIO_SetLow(GPIO5,GPIO_BIT4)
 对所用引脚配置工作模式函数为:
void TFT_config(void)
  SYS_EnableAHBClock(APB_MASK_GPIO5);
  GPIO_SetOutput(GPIO5,GPIO_BIT0);
  GPIO_SetOutput(GPIO5,GPIO_BIT1);
  GPIO_SetOutput(GPIO5,GPIO_BIT2);
  GPIO_SetOutput(GPIO5,GPIO_BIT3);
  GPIO_SetOutput(GPIO5,GPIO_BIT4);
模拟SPI方式发送字节数据的函数为:
void LCD_Writ_Bus(unsigned char dat)
    unsigned char i;
    LCD_CS_Clr;
    for(i=0;i<8;i++)
        LCD_SCLK_Clr;
        if(dat&0x80)
           LCD_SDIN_Set;
        else
           LCD_SDIN_Clr;
        LCD_SCLK_Set;
        dat<<=1;
    LCD_CS_Set;
TFT屏初始化函数为:
void TFT_Init(void)
    LCD_RST_Clr;
    UTIL_IdleUs(20e3);
    LCD_RST_Set;
    UTIL_IdleUs(20e3);
    LCD_CS_Clr;
    LCD_WR_REG(0xCB);
    LCD_WR_DATA8(0x39);
    LCD_WR_DATA8(0x2C);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x34);
    LCD_WR_DATA8(0x02);
    LCD_WR_REG(0xCF);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0XC1);
    LCD_WR_DATA8(0X30);
    LCD_WR_REG(0xE8);
    LCD_WR_DATA8(0x85);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x78);
    LCD_WR_REG(0xEA);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x00);
    LCD_WR_REG(0xED);
    LCD_WR_DATA8(0x64);
    LCD_WR_DATA8(0x03);
    LCD_WR_DATA8(0X12);
    LCD_WR_DATA8(0X81);
    LCD_WR_REG(0xF7);
    LCD_WR_DATA8(0x20);
    LCD_WR_REG(0xC0);
    LCD_WR_DATA8(0x23);
    LCD_WR_REG(0xC1);
    LCD_WR_DATA8(0x10);
    LCD_WR_REG(0xC5);
    LCD_WR_DATA8(0x3e);
    LCD_WR_DATA8(0x28);
    LCD_WR_REG(0xC7);
    LCD_WR_DATA8(0x86);
    LCD_WR_REG(0x36);
    LCD_WR_DATA8(0x48);
    LCD_WR_REG(0x3A);
    LCD_WR_DATA8(0x55);
    LCD_WR_REG(0xB1);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x18);
    LCD_WR_REG(0xB6);
    LCD_WR_DATA8(0x08);
    LCD_WR_DATA8(0x82);
    LCD_WR_DATA8(0x27);
    LCD_WR_REG(0xF2);
    LCD_WR_DATA8(0x00);
    LCD_WR_REG(0x26);
    LCD_WR_DATA8(0x01);
    LCD_WR_REG(0xE0);
    LCD_WR_DATA8(0x0F);
    LCD_WR_DATA8(0x31);
    LCD_WR_DATA8(0x2B);
    LCD_WR_DATA8(0x0C);
    LCD_WR_DATA8(0x0E);
    LCD_WR_DATA8(0x08);
    LCD_WR_DATA8(0x4E);
    LCD_WR_DATA8(0xF1);
    LCD_WR_DATA8(0x37);
    LCD_WR_DATA8(0x07);
    LCD_WR_DATA8(0x10);
    LCD_WR_DATA8(0x03);
    LCD_WR_DATA8(0x0E);
    LCD_WR_DATA8(0x09);
    LCD_WR_DATA8(0x00);
    LCD_WR_REG(0XE1);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x0E);
    LCD_WR_DATA8(0x14);
    LCD_WR_DATA8(0x03);
    LCD_WR_DATA8(0x11);
    LCD_WR_DATA8(0x07);
    LCD_WR_DATA8(0x31);
    LCD_WR_DATA8(0xC1);
    LCD_WR_DATA8(0x48);
    LCD_WR_DATA8(0x08);
    LCD_WR_DATA8(0x0F);
    LCD_WR_DATA8(0x0C);
    LCD_WR_DATA8(0x31);
    LCD_WR_DATA8(0x36);
    LCD_WR_DATA8(0x0F);
    LCD_WR_REG(0x11);
    UTIL_IdleUs(120e3);
    LCD_WR_REG(0x29);
    LCD_WR_REG(0x2c);
 实现色彩清屏处理的函数为:
void LCD_Clear(unsigned int Color)
    unsigned int i,j;
    LCD_Address_set(0,0,LCD_W-1,LCD_H-1);
    for(i=0;i<LCD_W;i++)
        for (j=0;j<LCD_H;j++)
            LCD_WR_DATA(Color);
 在进行显示驱动测试时,为通过测试的效率,可在显示屏的初始化之后,直接以色彩清屏函数来测试,若屏幕被指定色彩所填充,则说明显示驱动有效;否则,说明驱动失败。
在配备字库的情况下,实现字符显示的函数为:
void LCD_ShowCharh(unsigned int x,unsigned int y,char num,char mode)
    char temp;
    char pos,t;
    unsigned int x0=x;
    unsigned int colortemp=POINT_COLOR;
    if(x>LCD_W-16||y>LCD_H-16)return;
    num=num-' ';
    LCD_Address_set(x,y,x+8-1,y+16-1);
    if(!mode)
        for(pos=0;pos<16;pos++)
          temp=asc2_1608[(unsigned int)num*16+pos];
          for(t=0;t<8;t++)
            if(temp&0x01) POINT_COLOR=colortemp;
            else POINT_COLOR=BACK_COLOR;
            LCD_DrawPoint(x+pos,y-t);
            temp>>=1;
      else
            for(t=0;t<8;t++)
                if(temp&0x01) LCD_DrawPoint(x+pos,y-t);
                temp>>=1;
 实现字符串显示的函数为:
void LCD_ShowStringh(unsigned int x,unsigned int y,const char *p)
    while(*p!='\0')
        LCD_ShowCharh(x,y,*p,0);
        y-=8;
        p++;
 实现汉字显示的函数为:
void showhanzi16h(unsigned int x,unsigned int y,unsigned char index,unsigned char s)
    unsigned char i,j,k;
    const unsigned char *temp=hanzi16;
    temp+=index*32;
    for(j=0;j<16;j++)
        for(k=0;k<2;k++)
            for(i=0;i<8;i++)
                if((*temp&(1<<i))!=0)
                    if(s==0) POINT_COLOR=WHITE;
                    else POINT_COLOR=RED;
                else
                    if(s==0) POINT_COLOR=RED;
                    else POINT_COLOR=WHITE;
              LCD_DrawPoint(x+j,y-k*8-i);
            temp++;
实现TFT显示屏驱动效果测试程序为:
int main(void)
   board_init();
   TFT_config();
   TFT_Init();
   LCD_Clear(RED);
   BACK_COLOR=RED;
   POINT_COLOR=WHITE;
   LCD_ShowStringh(10,80," 8:30:00");
   showhanzi16h(10,240,0,0);
   showhanzi16h(10,220,1,0);
   showhanzi16h(10,200,2,0);
   showhanzi16h(10,180,3,0);
   showhanzi16h(10,160,4,0);
   showhanzi16h(10,140,5,0);
   while (1);
经程序的编译与烧录,在按图1连接的情况下其测试效果如图2所示。
1 器件连接
2 显示效果
其实,该测试的意义还不止于此,在修改显示屏初始化程序和显示屏长宽参数的情况下,它还可以驱动更多的显示屏。
如驱动一款1.8寸显示屏的参数化函数为:
void Lcd_Init(void)
    unsigned int i;
    Lcd_Reset();
    LCD_WR_REG(0x11);
    UTIL_IdleUs(120e3);
    LCD_WR_REG(0xB1);
    LCD_WR_DATA8(0x01);
    LCD_WR_DATA8(0x2C);
    LCD_WR_DATA8(0x2D);
    LCD_WR_REG(0xB2);
    LCD_WR_DATA8(0x01);
    LCD_WR_DATA8(0x2C);
    LCD_WR_DATA8(0x2D);
    LCD_WR_REG(0xB3);
    LCD_WR_DATA8(0x01);
    LCD_WR_DATA8(0x2C);
    LCD_WR_DATA8(0x2D);
    LCD_WR_DATA8(0x01);
    LCD_WR_DATA8(0x2C);
    LCD_WR_DATA8(0x2D);
    LCD_WR_REG(0xB4);
    LCD_WR_DATA8(0x07);
    LCD_WR_REG(0xC0);
    LCD_WR_DATA8(0xA2);
    LCD_WR_DATA8(0x02);
    LCD_WR_DATA8(0x84);
    LCD_WR_REG(0xC1);
    LCD_WR_DATA8(0xC5);
    LCD_WR_REG(0xC2);
    LCD_WR_DATA8(0x0A);
    LCD_WR_DATA8(0x00);
    LCD_WR_REG(0xC3);
    LCD_WR_DATA8(0x8A);
    LCD_WR_DATA8(0x2A);
    LCD_WR_REG(0xC4);
    LCD_WR_DATA8(0x8A);
    LCD_WR_DATA8(0xEE);
    LCD_WR_REG(0xC5);
    LCD_WR_DATA8(0x0E);
    LCD_WR_REG(0x36);
    LCD_WR_DATA8(0xC0);
    LCD_WR_REG(0xe0);
    LCD_WR_DATA8(0x0f);
    LCD_WR_DATA8(0x1a);
    LCD_WR_DATA8(0x0f);
    LCD_WR_DATA8(0x18);
    LCD_WR_DATA8(0x2f);
    LCD_WR_DATA8(0x28);
    LCD_WR_DATA8(0x20);
    LCD_WR_DATA8(0x22);
    LCD_WR_DATA8(0x1f);
    LCD_WR_DATA8(0x1b);
    LCD_WR_DATA8(0x23);
    LCD_WR_DATA8(0x37);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x07);
    LCD_WR_DATA8(0x02);
    LCD_WR_DATA8(0x10);
    LCD_WR_REG(0xe1);
    LCD_WR_DATA8(0x0f);
    LCD_WR_DATA8(0x1b);
    LCD_WR_DATA8(0x0f);
    LCD_WR_DATA8(0x17);
    LCD_WR_DATA8(0x33);
    LCD_WR_DATA8(0x2c);
    LCD_WR_DATA8(0x29);
    LCD_WR_DATA8(0x2e);
    LCD_WR_DATA8(0x30);
    LCD_WR_DATA8(0x30);
    LCD_WR_DATA8(0x39);
    LCD_WR_DATA8(0x3f);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x07);
    LCD_WR_DATA8(0x03);
    LCD_WR_DATA8(0x10);
    LCD_WR_REG(0x2a);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x7f);
    LCD_WR_REG(0x2b);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x9f);
    LCD_WR_REG(0xF0);
    LCD_WR_DATA8(0x01);
    LCD_WR_REG(0xF6);
    LCD_WR_DATA8(0x00);
    LCD_WR_REG(0x3A);
    LCD_WR_DATA8(0x05);
    LCD_WR_REG(0x29);
将色彩擦除屏幕的函数改为:
void Lcd_Clear(unsigned int Color)
   unsigned int i,m;
   LCD_Address_set(0,0,X_MAX_PIXEL-1,Y_MAX_PIXEL-1);
   LCD_WR_REG(0x2C);
   for(i=0;i<X_MAX_PIXEL;i++)
      for(m=0;m<Y_MAX_PIXEL;m++)
          LCD_WR_DATA(Color);
则经过程序的编译和下载,其测试效果如图3所示。
3 测试效果
此外,在修改初始化程序及显示屏参数的情况下,对LCD屏也是起作用的,图4是一款0.96LCD屏,其测试效果见图5所示。
4 器件连接
5 测试效果
关键词: AG32VH407
2026-04-08 07:32:17     打赏
2026-04-15 08:41:45     打赏
点灯 亮屏,期待楼主后续作品
2026-04-15 09:12:17     打赏
模拟的SPI 接口屏幕这个屏幕的刷新率指标咋样
2026-04-15 10:15:19     打赏
学习了,谢谢分享!
共5条 1/1 1 跳转至
