电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 大虾看看用ADS1.2编译移植到XSCALED的UCOS的OS_CPU_A.S遇
共6条 1/1 1 跳转至页
大虾看看用ADS1.2编译移植到XSCALED的UCOS的OS_CPU_A.S遇到的问题
2005-06-27 19:40:43     打赏
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 60
60 00000028 MSREQ SPSR,r12 ; restore the SPSR
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 86
86 00000044 MSR CPSR,r1 ; and change to that mode
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 94
94 00000058 MSR CPSR,r0 ; return to IRQ mode
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 97
97 0000005c MSR SPSR,r12 ; restore SPSR_irq ready for return
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 107
107 0000007c MSR SPSR,lr ; recover the SPSR when the thread
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 110
110 00000084 MSR CPSR,lr ; recover the CPSR when the thread
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 124
124 00000094 MSR CPSR, r12
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 131
131 000000a4 MSR CPSR, r12
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 176
176 000000f0 MSR SPSR, r4 ; YYY+
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 178
178 000000f8 MSR CPSR, r4 ; YYY+
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 199
199 0000011c MSR CPSR, r4 ; CPSR should be SVC32Mode
11 Errors, 0 Warnings
关键词: 大虾     看用     ADS1.2     编译     移植     XSCALE
2005-06-27 21:17:00     打赏
把CPSR改成cpsr_cxsf试试
2005-06-27 22:42:00     打赏
还是不行啊
2005-06-27 22:48:00     打赏
改之后的错误为
Error : A1261E: MRS cannot select fields, use cpsr directly OS_CPU_A.S line 82
82 00000034 MRS r0,cpsr_cxsf ; get current mode info.
Error : A1261E: MRS cannot select fields, use cpsr directly OS_CPU_A.S line 92
92 0000004c MRS r2,cpsr_cxsf ; copy current cpsr_cxsf
97 00000054 MSR SPSR,r12 ; restore SPSR_irq ready for return
107 00000074 MSR SPSR,lr ; recover the SPSR when the thread
Error : A1261E: MRS cannot select fields, use cpsr directly OS_CPU_A.S line 122
122 00000084 MRS r12, cpsr_cxsf
Error : A1261E: MRS cannot select fields, use cpsr directly OS_CPU_A.S line 129
129 00000090 MRS r12, cpsr_cxsf
Error : A1261E: MRS cannot select fields, use cpsr directly OS_CPU_A.S line 151
151 000000a0 MRS r4, cpsr_cxsf
176 000000dc MSR SPSR, r4 ; YYY+
9 Errors, 0 Warnings
2005-06-28 00:34:00     打赏
晕,没出错的那些行你改它干啥呀。
说仔细点八,MRS后面的不要改,就用CPSR或SPSR;
MSR后面的改成CPSR_cxsf或SPSR_cxsf
2005-06-28 04:02:00     打赏
多谢版主,终于可以,能不能告诉是什么原因啊
共6条 1/1 1 跳转至页
