OpenVINOTM,给你看得见的未来!>>
电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Programmable-Gain Amplifier, Using the M
Programmable-Gain Amplifier, Using the MAX532 DAC
2012-04-14 19:25:48    评分
关键词: programmable gain amplifier, PGA, MAX532, programmable gain, programmable resistor, ac gain control
Abstract: This application note discusses how to use the MAX532 to build a programmable gain amplifier (PGA) that's suitable for AC gain control. No external components are necessary. Equations are provided to easily calculate the output values.
 Programmable-Gain Amplifier, Using the MAX532 DAC.pdf
关键词: Programmable-Gain     Amplifi
