AVR,DS18B20 哪位大侠有用AVR操纵DS18B20的C源程序啊?
我正在用mega16操纵DS18B20,但是现在用ICCAVR怎么也写不出可以正常工作的程序。不知哪位大侠有这方面的经验啊?
答 1:
这是某位网友的作品(可能就是在21ic下载的,我借助它编写了PPC8260上面读DS2520的程序,不敢掠美,特希望作者现一下身)
#include "io2313.h"
#include "macros.h"
#define BOOL unsigned char
#define TRUE 1
#define FALSE 0
#define SET_BIT(x, y) (x|=(1<<y))
#define CLR_BIT(x, y) (x&=~(1<<y))
#define GET_BIT(x, y) ((x&(1<<y))>>y)
#define PULLING_LOW() SET_BIT(DDRD, 0)
#define PULLING_UP() CLR_BIT(DDRD, 0)
#define READ_DQ() GET_BIT(PIND, 0)
#define SKIP_ROM 0xCC
#define READ_RAM 0xBE
#define CONVERT_T 0x44
void ShortDelay(unsigned char tt)
asm("_L2: subi R16,1"); // 1t
asm(" nop") // 1t
asm(" brne _L2"); // 2t/1t
asm(" nop"); // 1t
asm(" ret"); // 4t
unsigned char W1_Reset()
unsigned char c;
PULLING_LOW();
ShortDelay(198); // 500us
ShortDelay(198);
ShortDelay(198);
ShortDelay(198);
ShortDelay(198);
PULLING_UP();
ShortDelay(148); // 75us
c = READ_DQ();
if (c == 0x01)
return FALSE;
ShortDelay(198); // 300us
ShortDelay(198);
ShortDelay(198);
c = READ_DQ();
if (c == 0x00)
return FALSE;
return TRUE;
unsigned char W1_BitIO(unsigned char b)
if (b)
PULLING_LOW();
ShortDelay(2); //2us
PULLING_UP();
ShortDelay(18); //10us
b = READ_DQ();
ShortDelay(118); //60us
else
PULLING_LOW();
PULLING_LOW();
b = READ_DQ();
PULLING_UP();
return b;
unsigned char W1_SendByte(unsigned char c)
unsigned char i = 8;
do
c = c>>1|(W1_BitIO(c&1)?0x80:0);
} while(--i);
return c;
unsigned char W1_ReadByte()
return W1_SendByte(0xFF);
unsigned char W1_Command(unsigned c)
if (W1_Reset())
W1_SendByte(SKIP_ROM);
W1_SendByte(c);
return 1;
else
return 0;
int ReadTemperature()
union
unsigned char c[2];
int i;
} temp;
if (W1_Command(READ_RAM))
temp.c[0] = W1_ReadByte();
temp.c[1] = W1_ReadByte();
if (W1_Command(CONVERT_T))
else
return -1000;
return (int)(temp.i*5/4+1)/2;
else
return -1000;
答 2: 谢谢hudaidai了,也感谢原作者。谢谢两位了,我来用用看吧! 答 3: thank very much 答 4: 有本介绍icc的书上有现成的原程序 答 5: 我的网上有
#include "io2313.h"
#include "macros.h"
#define TRUE 1
#define FALSE 0
asm(" nop") // 1t
asm(" nop"); // 1t
asm(" ret"); // 4t
unsigned char c;
PULLING_LOW();
ShortDelay(198);
ShortDelay(198);
ShortDelay(198);
ShortDelay(198);
PULLING_UP();
c = READ_DQ();
if (c == 0x01)
return FALSE;
ShortDelay(198);
ShortDelay(198);
c = READ_DQ();
if (c == 0x00)
return FALSE;
return TRUE;
if (b)
PULLING_LOW();
PULLING_UP();
b = READ_DQ();
else
PULLING_LOW();
PULLING_LOW();
b = READ_DQ();
PULLING_UP();
return b;
do
} while(--i);
return c;
if (W1_Reset())
W1_SendByte(c);
return 1;
else
return 0;
union
unsigned char c[2];
int i;
} temp;
else
return -1000;
else
return -1000;
