电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » LPC213X之LCM1010 C++程序源代码用的什么C++??
2007-05-31 21:17:05     打赏
P0->IOSET = (1 << LCMDATA) | (1 << LCMWR) | (1 << LCMCS); val = 1 << (Count - 1);请问这个语句什么意思呀,1<< 是什么命令格式呀。我看了C++里也没有这个定义方式呀。这是什么C++呀?
来自HOTPOWER源码
LPC213XLCM1010 C++程序源代码
i nclude <LPC213XDEF.H>
#define WDI P0_11//
#define LCMDATA P0_6 //LCM1010数据端
#define LCMWR P0_7 //LCM1010
#define LCMCS P0_8 //LCM1010片选
#define LedSegS1 0x20
#define LedSegS2 0x40
#define LedSegS3 0x80
#define LedSegS4 0x02
#define LedSegS5 0x04
#define LedSegS6 0x08
//HCBD GAEF
#define LedSegA 0x04
#define LedSegB 0x20
#define LedSegC 0x40
#define LedSegD 0x10
#define LedSegE 0x02
#define LedSegF 0x01
#define LedSegG 0x08
#define LedSegH 0x80
#define LedChar0 (LedSegA + LedSegB + LedSegC + LedSegD + LedSegE + LedSegF )
#define LedChar1 ( LedSegB + LedSegC )
#define LedChar2 (LedSegA + LedSegB + LedSegD + LedSegE + LedSegG)
#define LedChar3 (LedSegA + LedSegB + LedSegC + LedSegD + LedSegG)
#define LedChar4 ( LedSegB + LedSegC + LedSegF + LedSegG)
#define LedChar5 (LedSegA + LedSegC + LedSegD + LedSegF + LedSegG)
#define LedChar6 (LedSegA + LedSegC + LedSegD + LedSegE + LedSegF + LedSegG)
#define LedChar7 (LedSegA + LedSegB + LedSegC )
#define LedChar8 (LedSegA + LedSegB + LedSegC + LedSegD + LedSegE + LedSegF + LedSegG)
#define LedChar9 (LedSegA + LedSegB + LedSegC + LedSegD + LedSegF + LedSegG)
#define LedCharA (LedSegA + LedSegB + LedSegC + LedSegE + LedSegF + LedSegG)
#define LedCharB ( LedSegC + LedSegD + LedSegE + LedSegF + LedSegG)
#define LedCharC (LedSegA + LedSegD + LedSegE + LedSegF )
#define LedCharD ( LedSegB + LedSegC + LedSegD + LedSegE + LedSegG)
#define LedCharE (LedSegA + LedSegD + LedSegE + LedSegF + LedSegG)
#define LedCharF (LedSegA + LedSegE + LedSegF + LedSegG)
static const unsigned char LedTab[] =
LedChar0,
LedChar1,
LedChar2,
LedChar3,
LedChar4,
LedChar5,
LedChar6,
LedChar7,
LedChar8,
LedChar9,
LedCharA,
LedCharB,
LedCharC,
LedCharD,
LedCharE,
LedCharF
void _delay_loop_(unsigned int);
void _delay_loop_(unsigned int val)
unsigned int i;
for(i = 0; i < (val * 60); i ++);
class SystemObj {//系统类
public:
SystemObj(void);//SystemObj的构造函数
public:
void SystemInit(void);
void WdtInit(void);
void ClrWdt(void);
class LcdObj {//系统显示菜单类
public:
LcdObj(void);//LcdObj的构造函数
public:
void LcdInit(void);
void LcdBuffersClear(void);
void LcdClear(void);
void LcdOpen(void);
void LcdClose(void);
void LcdWrite(unsigned char, unsigned char);
void LcdWriteCommand(unsigned char);
void LcdWriteData(unsigned char, unsigned char);
void LcdDisplay(unsigned char, unsigned char);
void LcdDisplay(unsigned long);
void LcdDisplay(unsigned short);
public:
unsigned char LcdBuffers[32];
SystemObj::SystemObj(void)
SystemInit();
void SystemObj::SystemInit(void)
{ PINSEL->PIN_SEL0 = 0;
PINSEL->PIN_SEL1 = 0;
PINSEL->PIN_SEL2 = 0;
P0->IODIR = 0;
P1->IODIR = 0;
WdtInit();
void SystemObj::WdtInit(void)
P0->IODIR |= (1 << WDI); // 设置WDI控制口为输出
void SystemObj::ClrWdt(void)
P0->IOPIN ^= (1 << WDI);
LcdObj::LcdObj(void)
LcdInit();
void LcdObj::LcdClear(void)
int i;
for(i = 0;i < 32;i ++) {
LcdWriteData(i, 0);
void LcdObj::LcdBuffersClear(void)
int i;
LcdBuffers[i] = 0;
void LcdObj::LcdInit(void)
P0->IODIR |= (1 << LCMDATA) | (1 << LCMWR) | (1 << LCMCS);
LcdBuffersClear();
LcdWriteCommand(0x24);
LcdWriteCommand(0x18);
LcdWriteCommand(0x01);
LcdWriteCommand(0x03);
LcdClear();}
void LcdObj::LcdOpen(void)
_delay_loop_(1);
P0->IOCLR = (1 << LCMCS);//打开片选信号
_delay_loop_(1);
void LcdObj::LcdClose(void)
void LcdObj::LcdWrite(unsigned char Data, unsigned char Count)
int i;
unsigned char val;
for(i = 0; i < Count; i ++) {
P0->IOCLR = (1 << LCMWR);//拉低读写时钟
if (Data & val) {
P0->IOSET = (1 << LCMDATA);//发送串行数据'1'
else {
P0->IOCLR = (1 << LCMDATA);//发送串行数据'0'
_delay_loop_(1);//等待LCM1010
P0->IOSET = (1 << LCMWR);//抬高读写时钟,打入串行数据
Data <<= 1;
void LcdObj::LcdWriteCommand(unsigned char Command)
LcdOpen();
LcdWrite(0x04, 3);
LcdWrite(Command, 8);
LcdWrite(0x00, 1);
LcdClose();
void LcdObj::LcdWriteData(unsigned char Addr, unsigned char Data)
LcdOpen();
LcdWrite(0x05, 3);
LcdWrite(Addr, 5);
LcdWrite(Data, 4);
LcdClose();
void LcdObj::LcdDisplay(unsigned char LcdBit, unsigned char LcdData)
unsigned char Addr;
Addr = LcdBit;
LcdOpen();
LcdWrite(0x05, 3);
LcdWrite(Addr, 6);
if (Addr) {
LcdWrite((LcdData >> 4) & 0x0f, 4);//HCB0
LcdWrite((LcdData >> 1) & 0x0f, 4);//DGA0
LcdWrite((LcdData << 1) & 0x06, 4);//0EF0
else {
LcdWrite(LcdData >> 4, 4);//S1S2S3 0
LcdWrite(LcdData, 4);//S1S2S3 0
LcdClose();
void LcdObj::LcdDisplay(unsigned long val)
unsigned char LcdData, temp;
int i;
LcdOpen();
LcdWrite(0x05, 3);
LcdWrite(0x0e, 6);
for(i = 0; i < 6; i ++) {
temp = val % 10;
val /= 10;
LcdData = LedTab[temp];
LcdClose();}
void LcdObj::LcdDisplay(unsigned short val)
int i, div;
div = 1000;
LcdOpen();
LcdWrite(0x05, 3);
LcdWrite(0x02, 6);
for(i = 0; i < 4; i ++) {
temp = (val / div) % 10;
div /= 10;
if (i >= 2) {
LcdData |= LedSegH;
LcdClose();}
SystemObj Sys;
LcdObj Lcd;
int main(void)
unsigned char K = LedSegS1;
unsigned long S = 1234;
unsigned short V = 0;
// Lcd.LcdDisplay(0x00, LedSegS1 + LedSegS4 + LedSegS6);//S1
Lcd.LcdDisplay(0x02, LedChar1);//LED1
Lcd.LcdDisplay(0x05, LedChar2);//LED2
Lcd.LcdDisplay(0x08, LedSegH + LedChar3);//LED3
Lcd.LcdDisplay(0x0b, LedSegH + LedChar4);//LED4
Lcd.LcdDisplay(0x0e, LedCharF);//LED5
Lcd.LcdDisplay(0x11, LedCharE);//LED6
Lcd.LcdDisplay(0x14, LedCharD);//LED7
Lcd.LcdDisplay(0x17, LedCharC);//LED8
Lcd.LcdDisplay(0x1a, LedCharB);//LED9
Lcd.LcdDisplay(0x1d, LedCharA);//LED10
Lcd.LcdDisplay(0x00, K);
Lcd.LcdDisplay(S);
Lcd.LcdDisplay(V);
while(1) {
S ++;
Lcd.LcdDisplay(S);
if ((S % 100) == 0) {
V ++;
Lcd.LcdDisplay(V);
if ((S % 500) == 0) {
if (K == LedSegS1) {
K = LedSegS2;
else if (K == LedSegS2) {
K = LedSegS3;
else if (K == LedSegS3) {
K = LedSegS4;
else if (K == LedSegS4) {
K = LedSegS5;
else if (K == LedSegS5) {
K = LedSegS6;
else K = LedSegS1;
Sys.ClrWdt();
_delay_loop_(500);
__nop();
关键词: LPC213X     LCM1010     程序     源代码     用的
