电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » RVDS与MDK-ARM比较
RVDS与MDK-ARM比较
2008-05-06 15:40:05     打赏
 http://www.realview.com.cn/wen-list3.asp?ID=275
RVDS
与MDK-ARM比较
ARM为不同的目标平台提供了不同的最优化的开发方案。
Microcontroller Development KitMDK是为满足基于MCU进行嵌入式软件开发的工程师需求而推出的。MDK包含了精确设备的调试和仿真支持,众多的案例模板和固件实例以及存储优化的RTOS库。它易于学习并能满足要求较高的微控制器应用。
RealView Development SuiteRVDS是为从事SoC、FPGA和 ASIC 设计的工程师,进行复杂的嵌入式应用和平台接口而设计的。RVDS向硬件设备的设计者提供多核调试、应用与所有的ARM处理器的代码产生和CORTEX CPU的配置等功能。它提供了到达第三方元件的接口(如ARM ESL tools)。
Feature
RealView Product
RealView MDK-ARM
General
Compilation Tools
RealView
RealView
Development Environment
µVision IDE
CodeWarrior
Debugger
µVision Debugger
RealView Debugger
Simulator
µVision Simulator
RealView ISS
Code Generation
RealView C/C++ Compiler
RealView Macro Assembler
RealView Linker & Utilities
Output Format
ELF/DWARF, HEX
ELF/DWARF, HEX
ARM-Based Microcontrollers
All ARM Cores
ARM Instructions
Thumb Instructions
Thumb2 Instructions
Device Database
Libraries & Examples
C/C++ Template Library
EABI Compatible
Third-Party Libraries
RTX Kernel Library
Example Programs
Delivered with extensive example projects you may use as templates for your own projects.
Delivered with generic ARM examples which show how to use the ARM CPU Core extensions.
Debugging
ELF/DWARF Input
HEX Input
Symbolic Object Input
JTAG Support
via ULINK
via RealView ICE
ETM Support
via Third-Party Trace
via RealView Trace
Third-Party Debugger Support
OS-Aware
for RTX Library
Configurable
Multi-Core Support
DSP Support
Cache Support
Simulation
Simulates Instruction Set
Simulates Startup Code
Simulates Interrupts
Simulates Peripherals
Target Visibility
User-Specific
Peripheral Dialogs
User-Configurable
Logic Analyzer
Execution Profiler
Code Coverage
Instruction Trace
Configurable BUS Timings
ESL Tools Interface
关键词: MDK-ARM     比较     RealView
