我昨天在猪八戒威客网里中了一标,标价1500块,高兴地不得了。突然想到,不如找几个电子高手来组队。
所以威客爱好者来加我为好友吧,我相信我能带好这个队,我会员号是dfh5454
如果业余的兴趣也可以先注册再加我,首页地址:http://www.zhubajie.com/task/?welcome=1078211
共7条
我是销售功率模块的,公司有很多现货,价格都还不错,做的品牌有EUPEC、SEMIKRON、MITSUBISHI、TOSHIBA等国际品牌,偏冷门模块和热销模块都有,有需要加我。
QQ:253743134 bellazhou
E-mail:bella@limaworld.com
MSN:limazhou@hotmail.com
WEB:www.limaworld.com
Ugg boots (sometimes called uggs) are a style of unisex sheepskin boots lined with wool on the inside and with a tanned outer surface. Ugg boots often have a synthetic sole, although this is not universal. Discount UGG Boots deserves great reputation. Heights range from around the ankle to above the knee, they are available in a range of different colours as both slip-on and lace-up varieties, and they are produced by a number of manufacturers. The natural insulative properties of sheepskin gives thermostatic properties to the boots: the thick fleecy fibers on the inner part of the boots allow air to circulate and keep the feet at body temperature. These famous ugg boots includes UGG Classic Cardy Boots, UGG Classic Tall Boots, UGG Classic Short Boots. This means that ugg boots can be worn without socks even in relatively cold weather.
共7条
